Old 04-21-2006
Steve West Steve West is offline
Newbie
Steve West is on a distinguished road
Sonar 5 trim question
I am sending my ADAT tracks into Sonar to do mixing and editing. Some of my tracks are a bit hot and I want to trim them down. When I move the input trims above the sliders they do nothing. How do I get the trims to work?
Steve
Old 04-23-2006
Twitch's Avatar
Twitch Twitch is offline
Senior Member
Twitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond repute
You can set each track lto peak out like at -6, or -12 and so forth or you can pre set the level before you even record onto that specific track or tracks..
http://www.myspace.com/infamoustwitch
Music is a moral law,
it gives wings to the mind, a soul to the universe
flight to the imagination, a charm to sadness
a life to everything,
Plato, 400 B.C
Old 04-23-2006
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Originally Posted by Steve West
... Some of my tracks are a bit hot and I want to trim them down.
Before or after they're in there? Trim (gain) once they're in. But nothing in Sonar will effect them at the inport or transfer stage. But if it's a digi transfer they shouldn't be exceeding zero right?
Wayne
Old 04-27-2006
jamie_drum jamie_drum is offline
Senior Member
jamie_drum is on a distinguished road
I would think if it's a digital transfer they should not be exceeding zero, assuming you are using the same bit depth and sample rate.
However, what sort of audio interface are you using? I don't use the digital inputs on my M Audio Audiophile, but I know that they can be set to Consumer or Pro level in the Audiophile control panel, and that presumably affects the level.
When I record audio, adjusting the trim changes the level of the recorded audio, so I don't know why it isn't working for you.
However, I would suggest the first place to try is the control panel or your audio interface.
Old 04-29-2006
Newbie
[QUOTE=jamie_drum]I would think if it's a digital transfer they should not be exceeding zero, assuming you are using the same bit depth and sample rate.
However, what sort of audio interface are you using? I don't use the digital QUOTE]
Well, I'm going into a HDSP9652 card from my ADAT machine through an optic link. I recorded the tracks on the ADAT a little hot, (a little red shownig from time to time), but I don't hear any distortion until I play back the downloaded tracks from my computer. I do notice that the track levels in Sonar and Samplitude show a hotter signal coming in than what I am reading on the ADAT meters. When I monitor the ADAT signal in Totalmix I don't hear any distortion as it's coming in and out of the card. For some reason the tracks are peaking out in the download process.
Now here is something to think about for awhile.
Steve
Old 04-29-2006
Just to be sure, you're not adding any gain in Sonar?
Wayne
Old 04-30-2006
Newbie
No gain in Sonar
No, no matter what I use-Samplitude, Sonar, Protools,Audition. For some reason I have to keep my levels on the ADAT 3db lower when I record because once it's dumped into my computer the gain rises to peak levels. It must have something to do with the way my computer handles my optic sound card.
Steve
Old 05-01-2006
DavidK's Avatar
DavidK DavidK is offline
Ravel wannabe
DavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond reputeDavidK has a reputation beyond repute
Or the level readout isnt accurate. I have noticed differences between formats. Maybe your levels on your ADAT are just reading incorrectly?
myspace
Old 05-02-2006
Newbie
ADAT level
Here's what I found. If you are just using the ADAT machine for analog in and analog out you can hit the red often with out audible distortion. However, if you are using just optic digital there is no forgiveness. One time through the "red door" and you have breakup. I don't know why this is, but I now know to record 3db lower when using optic outs.
Steve
Sonar MIDI question mithra6 Cakewalk / Sonar Forum 1 02-24-2006 08:08
Sonar 5 question Citizen Kane Cakewalk / Sonar Forum 4 01-20-2006 18:35
Multi-tracking/mixdown question in Sonar WagTheDog Cakewalk / Sonar Forum 5 10-25-2003 06:54
Sonar Purchase Question PCypert Cakewalk / Sonar Forum 1 09-13-2003 16:46
sonar users - question about the loop features maryslittlesecret Cakewalk / Sonar Forum 2 06-02-2001 07:51
