Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 04-21-2006
JonathanRay's Avatar
JonathanRay JonathanRay is offline
Senior Member
JonathanRay is on a distinguished road
Question Looking for a drum module (budget $450)
I'm interested in triggering my acoustic drums (mainly the kick and snare), for recording purposes. I've got about $450 to spend. Which module should I go with? I looking for something that sounds as natural and real as possible. What about the Alesis DM5? Thanks!
- Jonathan
Old 04-21-2006
Creamyapples1's Avatar
Creamyapples1 Creamyapples1 is offline
www.murphycabs.com
Creamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond repute
I believe the DM5 is a product of Alesis. I've not yet been able to test this unit, but I do have a whole DM5 kit on pre-order, available in May. That's about all I know.
Kevin - www.icanquitsmoking.org
The Small Business Workshop
My Generic Crap
The Murphy Cabinet Company
Custom Hardwood Amplifier & Speaker Cabinets
Old 04-21-2006
Senior Member
Oops, typo. Thanks for the reply.
- Jonathan
Old 04-21-2006
petermiller's Avatar
petermiller petermiller is offline
It is what it is
petermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond repute
the DM5 is a good unit. how are you planning to use this (computer,daw,analog) are you using outboard gear and a mixer. If your using a computer just track the drums in on seperate tracks and use drumagog. If you are using a mixer + outboard, get the DM5 as it can be configured to give you 4 seperate outs via panning and using the main out and aux out. Then I would post trigger the sounds off of the original drumtracs and blend the snare up underneath the original track and maybey just replace the kick with the new sample. the DM5 gives you random samples on the snare so its probably the best used for this purpose in this pricerange.
Peter Miller
Old 04-21-2006
Senior Member
I'm recording with a mixer which connects to my computer via firewire. I'd like to trigger the snare and kick, and mix the mic'd drums with the triggered sounds.
- Jonathan
Old 04-21-2006
It is what it is
then what you want is the DM5. here is what you do. Take a direct out of the original track on the mixer. thensend that to trigger input 1 on the DM5 (if you do not have direct out- use the insert point (one click in for send only) on TS cable.)
then assign the output to main out. go into the mix feature and pan this all the way left. that way the kick is on its own track. Do the same with the snare (in 2) main out all the way right. Adjust your triggering gains v curve crosstalk. Now take the two outs from the DM5 and put them into seperate channels on the mixer. treat them like they were regular inputs coming in. now you can mix/eq along with origibal sounds. you now still have 2 extra outs on the DM5 (toms maybe) for a total of four seperate tracks
works like a charm
Peter Miller
Old 04-21-2006
Senior Member
Wow thanks for the reply! So can I use my snare and kick mics as triggers?
- Jonathan
Old 04-21-2006
It is what it is
Thumbs up
absolutly you can. The kick is easy scince the scource is usually well isolated enough. There would be no problem w/ blead from other drums false triggering. the snare can be a little tricky sometimes. You might have to run an eq infront of the input to the module in order to isolate a triggering frequency. or gate the signal before it goes into the module. I do this all the time live. and in studio. It takes some getting used to but the results are worth it. I am assuming that you are not pre recording tracks then sending them back out to mix. This is all on the way in if I got you right. It is a lot easier in post to do this.
Peter Miller
Old 04-21-2006
Senior Member
Yeah, that's exactly what I need. Thanks a lot man, I really appreciate the help!
Oh yeah, what type of cable should I use to run from my mixer to the DM5? Just a mono cable, like a guitar cable? Thanks.
- Jonathan
Old 04-21-2006
Synkrotron Synkrotron is offline
Midician
Synkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond repute
yep
interesting... I didn't know you could use a mic as a trigger... I've been using piezo transducers to trigger my DM5
drum module advice back to gray Drums and Percussion 11 12-09-2004 16:11
WANTED Alesis D4 drum module hololog99 Free Ads for Music / Recording Equipment 2 11-23-2004 01:56
Midi drum stuff for the hard of thinking: Alan McGuinness Cakewalk / Sonar Forum 3 12-12-2002 12:03
A good drum module? rushfan33 Keyboards and Sound Modules 13 10-24-2002 11:43
drum module question discordJF Newbies 1 01-26-2000 08:17
