Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 04-20-2006
reshp1's Avatar
reshp1 reshp1 is offline
1K Silver Member
reshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond repute
Drum Storage
I may have to move into an apartment in the not so distant future and won't be able to have my kit. What's the best way to store them, for say, a year or too? Keep the kit assembled (drums/cymbals on hardware), disassemble but keep heads on, disassemble and take heads off? Other things to look out for?
I wish my lawn was Emo so it'd cut itself.
Old 04-20-2006
drummer_goat drummer_goat is offline
Newbie
drummer_goat is on a distinguished road
Why not get a storage unit, put some carpet up and use it as a practice space?
Old 04-20-2006
breeeeza's Avatar
breeeeza breeeeza is offline
Senior MemBREH
breeeeza has a reputation beyond reputebreeeeza has a reputation beyond reputebreeeeza has a reputation beyond reputebreeeeza has a reputation beyond reputebreeeeza has a reputation beyond reputebreeeeza has a reputation beyond reputebreeeeza has a reputation beyond reputebreeeeza has a reputation beyond reputebreeeeza has a reputation beyond reputebreeeeza has a reputation beyond reputebreeeeza has a reputation beyond repute
if you are storing it for a year or two then it is a good idea not to stack them one above each other with the heads on as this will just stretch the heads and when you come to play with them again the heads will be ruined.
Old 04-20-2006
phaqu's Avatar
phaqu phaqu is offline
Micter licks balls
phaqu has a reputation beyond reputephaqu has a reputation beyond reputephaqu has a reputation beyond reputephaqu has a reputation beyond reputephaqu has a reputation beyond reputephaqu has a reputation beyond reputephaqu has a reputation beyond reputephaqu has a reputation beyond reputephaqu has a reputation beyond reputephaqu has a reputation beyond reputephaqu has a reputation beyond repute
Find a band that needs a drummer, then set em up at their place. ( Done that more than once.)
Old 04-20-2006
petermiller's Avatar
petermiller petermiller is offline
It is what it is
petermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond repute
make shure to leave the heads on. make shure there is no moisture where you are going to keep them. and also no extreme/rapid changes in temperature. If you got cases leave them in them. If you don't I suggest you go get some. Anyway drums are pretty durable. I have plenty of kits from the sixtys and I am shure they havn't been in active use for 40+ years without sitting somewhere at some time. So I wouldn't dwell too too much on this one.
Peter Miller
Old 04-20-2006
reshp1's Avatar
1K Silver Member
I wish.
Just started a few months ago, I doubt anyone would want me as a drummer. So leave the heads on but don't stack, is that the general concensus?
I'm a guitar player, so... we're weird about storing our instruments long term.
Old 04-21-2006
mikeh mikeh is offline
2.5K Gold Member
mikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond repute
Leave the heads and rims on to secure the round of the drum. It's not a bad idea to loosen the heads a little (not a lot). Certainly cases are a good idea - even if it's only soft shell.
As already discussed make sure moisture can't impact the drums and if possible avoid extremes in climate.
When I have to stack drums, I place plywood betwwen each drum. The plywood is cut so it sits on the rim (not on the head). As an example 14" drum with 16" plywood on top and then the 12" drum on the plywood.
Old 04-21-2006
foreverain4 foreverain4 is offline
1K Silver Member
foreverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond reputeforeverain4 has a reputation beyond repute
even if the preasure is on the rim, you are still stretching the head. the absolute best way is hard shell cases...
Lynn
www.trhrecorders.com
Kick Drum Miking Question zackformula Microphones 18 06-22-2006 07:28
Unusual problem with mic bleed... name_goes_here Drums and Percussion 8 08-15-2004 18:16
3 Drum Map Queries ebitda Cubase User Forum 2 07-07-2004 13:32
Cheap drum triggers/pads Lopp Drums and Percussion 7 04-09-2003 22:58
how to get that loud,low-end,kick drum click sound step by step right here ZEKE SAYER Drums and Percussion 31 05-20-2002 15:55
