Old 04-20-2006
juzcook juzcook is offline
Newbie
juzcook is on a distinguished road
Exclamation Problem with my UB2442 Mixer
Well I haven't used my mixer for about a month, and I was just setting everything up at home to record my band's jam sessions. So I've set everything up, and I decide to do some sound checks to get the levels right... but when I line in to my comp, I notice the elvels aren't appearing to be very loud OR clear. Also, when I pick some notes to check the levels, my monitor on the mixer (the series of lights that light up based on volume input) don't light up at all. I tried different mics, leads and channels and they're all the same. So I'm guessing my mic pre-amps are the problem? The lights do light up when u remove a mic or something from the channel, which is odd. Can anyone give me some dieas on what's causing this and how I can go about getting it fixed? Thanks
Old 04-20-2006
SuperGeek's Avatar
SuperGeek SuperGeek is offline
Plotting World Domination
SuperGeek has a reputation beyond reputeSuperGeek has a reputation beyond reputeSuperGeek has a reputation beyond reputeSuperGeek has a reputation beyond reputeSuperGeek has a reputation beyond reputeSuperGeek has a reputation beyond reputeSuperGeek has a reputation beyond reputeSuperGeek has a reputation beyond reputeSuperGeek has a reputation beyond reputeSuperGeek has a reputation beyond reputeSuperGeek has a reputation beyond repute
Not sure on that board but is it in PFL mode ( prefade listen) setting and then soloing to set the gain control (mic/line)
Have you pluged into the correct out puts and asigned the channels correctly.
as for the led/meter believe that that has to be in one of the modes selected by a push button.
Crossing my fingers this will help you
Real engines don't have spark plugs
Old 04-20-2006
Wish14's Avatar
Wish14 Wish14 is offline
But it's a dry heat...
Wish14 has a reputation beyond reputeWish14 has a reputation beyond reputeWish14 has a reputation beyond reputeWish14 has a reputation beyond reputeWish14 has a reputation beyond reputeWish14 has a reputation beyond reputeWish14 has a reputation beyond reputeWish14 has a reputation beyond reputeWish14 has a reputation beyond reputeWish14 has a reputation beyond reputeWish14 has a reputation beyond repute
I just had a problem with my UB1204FX mixer....I would turn on the power and none of the LEDs would light up...The phantom power LED would come on if I flipped the switch, but that was the only thing that indicated any power was getting into the unit.
I had a guy fix it and it turned out the problem was a bad diode and capacitor in the power supply. The capacitor went bad and shorted the diode. He was able to fix it for $45....cheaper than buying a new mixer.
I did a little research online at various forums and it looked like Behringer may have had a problem with those capacitors failing for units manufactured in mid-to-late 2002. There's a tag on the back of the mixer with the manufacture date...mine was from 0702, so it fits in with the time frame of the possible problem.
After the fix, everything is good to go....the mixer actually seems a little quieter...the guy who fixed it says the bad capacitor could have been adding some noise....
So....don't know if your problem is the same...but I thought I'd throw it out as it kinda sounds similar....
Good luck!
Q: Is it good music?
A: I Wish
Old 04-20-2006
Newbie
Thanks for your input guys, I don't think it would have much to do with buttons I have on because the alst time I used it it was fine... and I did try pressing them all. I don't particularly want to send it away under warranty because I NEED my mixer . Any ideas where I could take it to get it fixed? I bought it off of an ebay store, so I can't take it to my favourite music store or they'll be like "eh?". I'll check the year thing when I get home (I'm at work).
Behringer UB1204 mixer and MIC2200 hookup problem SirTemplar Digital Recording & Computers 0 03-13-2005 09:42
Problem hooking my computers up to my mixer xdavidx Digital Recording & Computers 4 05-17-2004 14:12
mackie mixer problem; noise no-sleep Mixing / Mastering 6 12-17-2003 21:23
Digital Mixer (Yamaha O2R) or a good analog mixer with a controller? pisces7378 Digital Recording & Computers 6 10-31-2002 14:54
HELP ! M2600 mixer problem DustyCat Other Equipment and Reviews 3 05-07-2000 00:38
