Old 04-19-2006
dhbailey dhbailey is offline
Newbie
dhbailey is on a distinguished road
Setting Monitor levels
Now that I've reorganized my studio (small office) to include a pair of M-Audio BX8a monitors I have a question on setting the levels:
A) should I leave the level on the monitors turned up full and adjust the actual sound level by the fader on whatever source I am monitoring?
-or-
B) set the monitor level on my KorgD3200 recorder to the zero mark and then adjust the levels on the monitors to a comfortable listening level?
Will it make a difference in what I'm able to hear in my recordings?
Thanks for any insights anybody cares to share!
Old 04-19-2006
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
B.
You should fine a "home" mark on whatever you're using as an attenuator and set that at a specific level (arguably, 85dBSPL calibrated from a pink noise file at around -15dBRMS). That is, each speaker to 79dBSPL.
If you want to use the K-System, you can read up on that at www.digido.com - The settings are different, but similar and metering comes into play.
Yes, it will make a difference in your recordings as you get used to relative density at specific volumes.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Help with setting up proper mic trim levels StupidKid Drums and Percussion 0 10-15-2004 00:42
Need some help setting my compressor please cjacek The Rack 2 05-26-2003 04:26
Sonar reverb setting and saving to midi mhuang Cakewalk / Sonar Forum 1 03-28-2002 07:38
Multitrack Recording in a Live Setting SN115 Recording Techniques 0 02-03-2001 22:44
window98 display setting is getting out of hand!! please help istyle Digital Recording & Computers 4 01-17-2001 03:09
