MicroKorg and Reason
I just got a MicroKorg and it sounds great but I want to control Reason 3 with it as well. Keys, Pitch, and Mod wheels sink up but I cannot get the 1-5 edit controls to be detected in Reason. Does anyone know how to assign these to parameters in Reason?
Thanks T |
is the midi indicator showing that there is incoming data when you move the controls?
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual |
The midi indicator flashes but there are no change in the reason parameters. Tried right clicking and remote overide but this did not work. I did notice that midi channel (7) always works no matter what you assign it to, but none of the other channels. Any ideas?
Try going into the 'Preferences/Control Surface' page and choosing 'Korg' then '<Other> (MIDI Keyboard w Controls)'.
You may need to try a shareware program called Midi-Ox --- LINK --- to find out what those five edit controllers are sending over midi. I don't an explanation for the channel 7 thing without more info...
...now in HD. |
Thanks ssscientist that helped!! Im still not sure if it is running correctly. Now the controls work but there is a lot of cross-talk, some of the controls are running more than one parameter at once (i.e.: Knob 4 controls Filter 1's release, and the portamento control on the Subtractor). I can remote override objects now so that is a big plus!! Ill probably have to go through and turn off some CC#'s. You think they would just assign a driver for this thing since it’s so popular. This is more of a pain in the neck than i had hoped, I should have just got a USB controller. I will look into the Midi OX maybe that will help. Thanks again for the help.
Later T |
| Nord Lead, microKORG sounds for controller | h2blink | Keyboards and Sound Modules | 5 | 07-27-2005 10:44 |
| between the microkorg & the yamaha s03... | trim | Keyboards and Sound Modules | 3 | 08-29-2003 22:08 |
