Old 04-18-2006
shackrock's Avatar
shackrock shackrock is offline
1K Silver Member
shackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond repute
power amps, speaker ratings, etc.
so....if I have an amp that is rated at (this is just an example) 1500w rms per channel stereo...and I have 2 speakers that are rated at 1000w rms....and I try to turn my amp up to max...do i blow my speakers? i was always under the impression that the speakers set the limit, not the amp....and that the amp would only provide what the speakers can handle......but i've read otherwise now...and i'm just getting confused...my EE isn't helping me out either. anyway can somebody clarify? ha
Scott Solo
Old 04-19-2006
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
No, you willnot blow the speakers just by turning the amp up. If you do, there was already a problem with the amp. Most pro audio companies power between 2 and 3 times what the speakers are rated for. Blowing speakers happens much quicker when you underpower and as a result of trying to bump up levels in an attempt at more volume, your amplifier clips the signal and passes it on all screwy like (squared even) and the poor speakers just fry. If you happen to be REALLY overpowered though, there is a chance you could blow the speakers with sheer volume, but there will be audible signs of that before the speakers get into any trouble. You should have time to make an adjustment in your mix before that happens unless it happened to be a specific and fast event that takes everything out at once.
Dealer for Peluso Microphones, Blue Microphones and CBI cables....
http://www.myspace.com/xstaticstudios
Hey Everyone: PA System??? IronsideMessiah Other Equipment and Reviews 32 02-19-2006 10:28
im looking for good monitors? metalmansam Mixing / Mastering 19 01-11-2006 08:56
Power Handling (noise / program / peak): 250 / 500 / 1000 watts. earworm Live Events 5 12-15-2005 22:31
power amps for moniters notbradsohner Mixing / Mastering 3 03-01-2004 22:34
Advice on a Stereo Power Amp and Speaker Cabinet Lun Other Equipment and Reviews 5 12-09-1999 11:27
