Old 04-17-2006
Albertm's Avatar
Albertm Albertm is offline
Dedicated Member
Albertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond repute
Tail off of song
I did a midi peice in Sonar 5. At end of piece it trails off nicely. When I change from midi to audio with Bounce to Tracks command so I can burn to CD, the end of song trail is gone. It just cuts off. I added reverb to overall track. It does work but I wanted track dry. Also tried just exporting midi tracks as WAVE. (I read once that you need not convert soft synth tracks to audio, I forget where in these pages) But there was no sound. Didnt seem to work.
I even Set the Options/Audio/Adnaced setting to "Play effect Tails" (But it seems not to make a difference, probably becuase there are no effects)
Any ideas why the trail cuts off when converting midi to audio , any trick I can use to keep trail even if dry? Hope this made sense. Thanks
Old 04-17-2006
Synkrotron Synkrotron is offline
Midician
Synkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond repute
On a MIDI track, try adding a note, doesn't matter which and on what track, a good 4 to 6 bars after that actual end of your song. Sonar will now continue to play after the end of your song and won't stop any effects tails. It doesn't matter if that extra note you've added plays because you'll edit that out in your favorite wave editor.
Old 04-18-2006
DM1 DM1 is offline
Senior Member
DM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond reputeDM1 has a reputation beyond repute
Sonar only bounces/exports the selected range. When the effect or instrument tail is outside this range, it gets cut off.
The selected range is shown on the time ruler at the top of your project, and in the Select toolbar. You can edit it using either. In the toolbar, just punch in a new "thru" time. Add as many seconds or bars as you need to capture the full instrument decay and release. Alternately (and the method I use,) you can click on the time ruler while holding down <ctrl> to extend the selected range.
Old 04-18-2006
Albertm's Avatar
Dedicated Member
ah, that makes sense. I will try that next time. I already used the Synkrotron method which worked great too. Thanks
Old 04-18-2006
Midician
more than one way to skin the proverbial cat it seems
Alesis HD24XR jlizard Alesis Forum 10 01-30-2008 08:14
Wanted: Great Female Pop/Rock Song TexRoadkill Songwriting, Singing & Vocals 12 12-22-2007 11:00
NEWBIES - THE ART OF MASTERING YOUR SONGS (an introduction) manning1 Newbies 46 04-29-2005 14:06
NEWBIES - article - some techniques for writing/producing songs. manning1 Newbies 14 04-06-2005 16:42
New Song: "How To Acheive Your Goals Without Actually Trying" Eurythmic MP3 Mixing Clinic 6 10-06-2001 17:58
