Old 04-17-2006
cracklin' cracklin' is offline
Junior Member
cracklin' is on a distinguished road
tascam 38 + 388
I met a guy who is willing to sell his working tascam 38 for $300. First off: is this a good deal?
I am already using a tascam 388 and really like it. I was wondering if I could somehow combine the two machines. I would really enjoy not having to bounce down 8 tracks just so I can add two more. so the extra tracks would rock.
I also have a mackie 1604 that I figure i could use to mix all the tracks from both machines...but i would definately want to use the preamps in the 388 for tracking. I just figure that $300 for the 38 might be too good of a deal to pass up...but i dont really know.
any ideas would help...
Old 04-17-2006
SteveMac's Avatar
SteveMac SteveMac is offline
Force of Nature
SteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond reputeSteveMac has a reputation beyond repute
I don't know about synching the two. I'm sure someone here does, but a 38 in good working condition fo r $300 is a good deal.
Old 04-17-2006
Beck's Avatar
Beck Beck is offline
Analog Partisan Ranger
Beck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond reputeBeck has a reputation beyond repute
The 388 can be master or slave, so it could be synced to the 38 or anything else with an external synchronizer using SMPTE.
What Kind of music do you record? Drum machines, keyboards? Real drums and guitars?
You will need to invest in an external synchronizer and special cables. You will give up a track on each machine for a sync track, so you’ll have a 14-track system. You will have two different tapes to keep track of, one ½” for the 38 and as you know, ¼” on the 388. If you spread your tracks across these two formats you will always have to have those two machines to play the raw tracks.
It can be done, but I don’t recommend it in most cases.
«:: «::B::» «::E::» «::C::» «::K::» ::»
"Where in the hell are the red M&M's?"
~My Lil' Sister, 1976
Old 04-17-2006
petermiller's Avatar
petermiller petermiller is offline
It is what it is
petermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond repute
You can sync the two as previously mentioned. the 38 is a good machine but if you can find a TSR8 you would be much better off in the sync department+ newer mor pro level unit. I would check the unit out first. If it has been moved a lot you should check head alignment (zenith azimuth etc. ) Tascam did make a control for midistudios in the 80's called the TDM1000 midizer that could be used as a time clock via smpte and will also generate smpte so you can stripe one track of each machine in order to sync the two. also if you are doing this mke shure to give yourself enough time between each take so as to allow the two units to sync up. It takes a few seconds.
Peter Miller
My new TASCAM 388 + LOTS of pictures!! cjacek Analog Only 86 08-19-2008 13:12
Tascam 388 Users? Joe Nathan TASCAM User Forum 2 02-26-2006 15:13
Just got a Tascam 388 for Free Carbona Analog Only 19 09-06-2005 15:28
Link a Tascam 424 and 388 carquinez Recording Techniques 10 06-16-2005 12:37
FS/FT: Tascam 388, Han-D-Mag, ART Phantom II's, Hosa snake curtiswyant Free Ads for Music / Recording Equipment 0 04-04-2005 11:35
