Old 04-16-2006
DarkCide DarkCide is offline
Senior Member
DarkCide is on a distinguished road
Midi Drums and Sonar
I've exported Guitar Pro drum tracks into a midi. I want to be able to manipulate the different sounds/volume of each instrument. Is it possible to do with Sonar? Do I need a synth? How do I do it?
Old 04-16-2006
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
Your terminology has me a bit confused as to what you are asking.
Do you mean you created a midi track? If so, then yes you need a synth to play it back. This can be a hardware synth (sound card, keyboard) or a software synth (DXi or VSTi). Sonar comes with a couple of general midi DXi's that you can use if you don't have a hardware synth, or want to expand your choice of sounds.
I believe the newer versions of Sonar also come with a sound font player, so you can also use sound fonts. There are quite a few free sond fonts available on the web.
Old 04-16-2006
Senior Member
Ok, I've been able to use the software synth cyclone to play the midi drums tracks.
Is there a way to change the sounds of each instrument such as the kick, snare through the synth? All the drum instruments seem to be playing through the same channel 10 and I can't seem to be able to control each seperately!
Old 04-16-2006
dachay2tnr's Avatar
One Hit Wonder
You could put each drum on its own midi track and run it to a separate instance of the DXi. There is a Cal program that will split the notes out for you. It's called Split Notes to Tracks.
However, I prefer to do it manually, since I like to keep certain notes grouped together on one track, e.g., Open, Closed and Pedal Hi Hat. What I find fairly easy is to clone the drum track a few times, and then delete whichever drums I don't want from each track. You can select an entire drum sequence by clicking on the corresponding piano key. This will highlight the entire track for that particular note, then just hit the delete key.
Old 04-16-2006
Senior Member
Now I'm using Battery 2 is my software synth and there is no sound coming out. Some synths work and some don't. I've noticed battery's pads blink so I know it is reading the midi signal. How can I make it produce sounds?
I was able to clone the midi tracks and will use your preferred method by deleting instruments in the piano roll. How do you adjust the volume of each seperate instrument and can you change the sample (sound) for each instrument?
Old 04-16-2006
dachay2tnr's Avatar
One Hit Wonder
Don't own Battery, so I can't help you there. Sorry.
As for adjusting volume, if you use a separate instance of the DXi, you can adjust the volume on the audio track that it is patched to. Although some (most?) DXi's have individual volume controls within the DXi control panel. Depends on the DXi and your preferred approach I guess. However, multiple instances of a DXi will chew up CPU power in some cases.
Old 04-16-2006
ariyus's Avatar
ariyus ariyus is offline
Newbie
ariyus is on a distinguished road
u have to assign a wav files on each of the blinking pads... so u must have sample files (drumkit) ..blinking means the pads have been triggered by your midi files... u almost got it...
Old 04-16-2006
Senior Member
Thank you very much. Worked nicely!
How is it possible to know what instrument each trigger is without experimenting by adding a sound first.
For example, you have all kinds of pads blinking when the drums are playing, how do you know which is the highhat, snare, kick...etc?
Old 04-16-2006
ariyus's Avatar
Newbie
i often arrange midi file using piano roll... it is much easier.. u can click a note on piano and hear what sound will come out...
but each pads in battery 2 has a key range assigned... u can check it on cell tabs > cell control > key range...
hope that helps...
MIDI guru needed elect drums soundfonts wfaraoni MIDI Mania 9 06-19-2006 10:36
Midi drums, midi keys, Sonar 2 problem Cartwright MIDI Mania 3 06-02-2005 09:04
Midi drums, midi keys, Sonar 2 problem Cartwright Cakewalk / Sonar Forum 2 06-01-2005 07:01
Can I write midi drums linking FL studio like in SONAR? clintusmaximus Cool Edit Pro / Adobe Audition Forum 1 09-11-2004 02:46
using yamaha dtxpress drums w Sonar Midi?? wfaraoni Cakewalk / Sonar Forum 0 03-07-2003 23:05
