Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 04-15-2006
jingleheimer jingleheimer is offline
Junior Member
jingleheimer is on a distinguished road
Drum frequency ranges?
OK heres my problem. I have recently started recording local bands in my homestudio and when it comes to drums i always seem to feel lost. when it comes to micing drums i never seem to know what mic i want to use because im not sure of each drums frequency range. So if anyone could by chance provide me with a chart or some insight as to what drums produce what Drum frequency ranges that would be amazing. THANKS FOR ALL THE HELP -Jingleheimer-
Old 04-15-2006
jonnyc jonnyc is offline
2.5K Gold Member
jonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond repute
I'm not sure how knowing the exact frequencies are going to help in micing. Now for mixing it could help. But just hit your drums and listen with your ears. Lower tones have a lower frequency, higher have higher. I've found that I can throw just about any mic on any source and get a good sound as long as you know what you're doing. I've mic'd, say toms for example, with both dark sounding dynamics, and really bright condensers. Just experiment.
Old 04-15-2006
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Use a kick drum mic for the kick drum.
An sm-57 will work for everything else (not so much on overheads)
Drums have really low fundamentals, but the harmonics and attack can be upwards of 10k.
And decent dynamic will work on toms and snare, you can use almost anything that would work on a bass guitar (and take the pounding) on a kick. Condensers for overheads.
That's it.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 04-16-2006
Gamelan Gamelan is offline
Junior Member
Gamelan has much to be proud ofGamelan has much to be proud ofGamelan has much to be proud ofGamelan has much to be proud ofGamelan has much to be proud ofGamelan has much to be proud ofGamelan has much to be proud ofGamelan has much to be proud ofGamelan has much to be proud of
Different drums and tunings will be different. On average... The meat of the snare is around 200 and the crispies are between 5 and 8k. Toms are between 90 and 175 with the stick around 5k, bass drum is between 50 and 80. Mics with a roundish bottom tend to work well for close micing drums. Pretty much anything you might use for voice-over, sm7, re20 or 421 for example. A 57 or 58 is ok on any drum in a pinch, but a little flat compared to other options.
Old 04-17-2006
Junior Member
Hey thanks for all the help its great -Jingleheimer-
Recording Settings Chart or something.... zenabi Mixing / Mastering 19 01-21-2006 08:07
Drum Machine V Sample Cd rxkevco The Rack 2 01-14-2006 08:22
Drum machine software plugins (VSTi,DXi) to a PC Multi Trk ??? Submission Newbies 5 01-09-2006 21:35
Midi drum stuff for the hard of thinking: Alan McGuinness Cakewalk / Sonar Forum 3 12-12-2002 12:03
EQ, compressing - in what order? BootCut Mixing / Mastering 37 11-16-2002 07:54
