Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 04-12-2006
sfcphilip sfcphilip is offline
Newbie
sfcphilip is on a distinguished road
MIDI in PT le 7
I have been using Reason Adapted and it is starting to make sense. I created a stereo aux track, then a stereo audio track, and finally a midi track to load the synth that I wanted to play. I used redrum to create the drum track and recorded it on audio track 1 in PT. Now, I want to use the combinator to add some melody along with the drum track. I created another audio track,record enabled it and proceeded to play the new sound. However, the output from Audio track 1 is being recorded on Audio track 2. I have tried to mute the Audio track and ensured that its output is not bused to the input of Audio track 2. I even tried to create a new midi track. What do I do? It has to be something simple.
Old 04-13-2006
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
Reason Adapted, like Reason, is a midi only application.
If I followed your post correctly you have not been able to get onto the second midi track and in my opinion the source of the problem is you're not content to leave midi tracks as midi tracks and allow them to run alongside the guitars, vocals, etc that you may have recorded in 'protools'.
Don't worry about converting the midi tracks from Reason Adapted into audio at any point before the final mixdown and your problem will be solved.
...now in HD.
Old 04-13-2006
Newbie
Thanks SSS,
You're right. I want to leave the midi tracks as midi tracks. However, if that's the case, then how am I going to use several midi tracks for one session? I like the different sounds in Reason Adapted and would like to use several of them for one session. All of which, I use my Roland D70 as a controller. Is is possible to use several MIDI tracks? If possible, would I have to create an Aux or Audio track for each midi track created? Thanks for your response.
Old 04-13-2006
sixways sixways is offline
Force of Nature
sixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond repute
I'm working on this same issue SFC...if I can resolve it, I will let you know.
I did notice that if you disable record on your first track, it does not get overwritten, but you still see the levels going up and down and hear the note. Its got something to do with assigning MIDI channels that you want to use...but again, I haven't figured it out yet either.
6
Old 04-13-2006
Newbie
Hey thanks 6. I will keep plugging also. Take care.
Old 04-13-2006
TuoKaerf's Avatar
TuoKaerf TuoKaerf is offline
Music To Punch Babies To
TuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant futureTuoKaerf has a brilliant future
have you selected the output of the MIDI track to be Redrum? Then on the new one, selected Combinator?
Digi Certified
http://www.protoolsforum.com/images/PTBanner.jpeg
Software samples for MIDI, what do I need to know? Vigilante Recording Techniques 3 12-06-2005 23:54
How do I hook everything together? mikara Newbies 20 09-02-2005 05:27
Midi and Creamware dangerman MIDI Mania 3 05-18-2005 00:53
drum machine, Cakewalk, USB MIDI interface, argh 55337 Newbies 14 03-09-2005 16:41
Oriion, Rebirth & Fruityloops with Sonar acgt Cakewalk / Sonar Forum 10 09-13-2002 13:21
