Speeding up audio process selection?
I tend to use the same audio process on numerous tracks over and over again. It gets tedious to go Process / Audio Effects / Sony / Pitch Shift (or) Wavehammer over and over again. There are so many effects in the list, I have to keep scrolling to the same spot all the time.
Is there a way in Sonar 4 to shorten this hunt and peck process? A macro key would be great! |
I'm at work at the moment but if I get a chance I'll have a look tonight. I'm on Sonar 5 SE but I'm sure that if I can suss something out in 5 it should work in 4 |
I use the "Clone Track" option a lot, with the "clone events" option unchecked (so it just copies the effects and settings.)
I've also created a template that has 4 tracks, each with all my usual plugins already assigned, and I start new projects from that template. It's way easier to delete tracks that aren't needed than it is to add the same 3 plugins from the enormous plugin list. |
Obviously, however, a lot depends on your CPU and what it can handle. But until Sonar starts choking, I would leave everything in real time. BTW, a Wavehammer to every individual track is waayyyyy overkill IMO. You might want to look at your signal chain to find out why your recording signal is so low that you feel this is necessary. You really should only need to apply the Wavehammer to your Master Bus (and *need* is questionable even in that situation). |
I guess I was using that as an example. I have so many effects in a list that I hate having to hit the menu and scroll through the effects to get the reverb I'm looking for. From some of the answers here, I think I'll try the clone track or file template feature. Should be good for grinners! |
| External FX -> Can be used as Audio Process - Plugin? | mrbowes | Cubase User Forum | 5 | 11-03-2005 06:36 |
| Does my Logic Audio Platinum process audio in 32 or 24 bit? | pisces7378 | Digital Recording & Computers | 4 | 11-19-2002 09:59 |
| ARRGH: Audio folder for recording externally mixed audio in 5.1 | Lopp | Cubase User Forum | 0 | 10-04-2002 15:54 |
| Audio to PC MIDI Sync | mark4man | Fostex Forum | 0 | 07-21-2002 08:45 |
| PC DAW Digest | TAE | Digital Recording & Computers | 0 | 11-25-2000 09:03 |
