Old 04-11-2006
EdJames's Avatar
EdJames EdJames is offline
Senior Member
EdJames has a reputation beyond reputeEdJames has a reputation beyond reputeEdJames has a reputation beyond reputeEdJames has a reputation beyond reputeEdJames has a reputation beyond reputeEdJames has a reputation beyond reputeEdJames has a reputation beyond reputeEdJames has a reputation beyond reputeEdJames has a reputation beyond reputeEdJames has a reputation beyond reputeEdJames has a reputation beyond repute
Question SE Electronics REFLEXION FILTER
http://www.dv247.com/invt/froogle/31474/
Has anybody used this and is it any good? I understand that you hook it up behind the microphone attaching it to the mic stand. Is that right? Does it have the desired effect or is it just an overexpensive gadget?
ED JAMES
"I wear shades indoors and sometimes speak in the third person, does that REALLY make me such an asshole?"
MUSIC EQUIPMENT OWNED:-
M-Audio Delta 44, ART Pro Channel and Audio Technica AT 4040 for recording Pop/RnB male vocals
Old 04-11-2006
drummerdude666's Avatar
drummerdude666 drummerdude666 is offline
immature
drummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond repute
I've seen it at a trade show before and i had a play with it. Unfortunatly with all the noise there - you couldn't tell how it was affecting the sound. But it sits behind the mic attached to the mic stand as you thought.
From soundcontrol.com (http://www.soundcontrol.co.uk/mod_1/....1.5.5-122-30#)
http://www.soundcontrol.co.uk/images...5.5-122-30.jpg
What is the Reflexion Filter?
The Reflexion Filter is basically a portable device for recording live sources with reduced room ambience. It is an advanced composite wall which is positioned behind any microphone by means of a variable position stand clamp assembly which ships with the product. The main function is to help obtain a 'dry' vocal or instrument recording. This is especially useful in studios without proper acoustic treatment, but can also be used to help record takes in control rooms, where the performer also has to operate the recorder, or in rehearsal studios to reduce ambient noise.
The Technical Bit:
The Reflexion Filter has 6 main layers. Firstly, a strong layer of punched Aluminium which allows sound waves to pass through it, diffused, to a layer of absorptive wool. The waves then hit a layer of Aluminium foil which helps dissipate energy and break up the lower frequency wave-forms, and from here they hit an air space kept open by rods passing through the various layers. The air gap acts as an acoustic barrier. The sound waves then pass to a further layer of wool and then through an outer, punched, Aluminium wall which further serve to absorb then diffuse the remaining acoustic energy.
The main absorber has formed pieces of Aluminium Foam attached to it via the extended separation rods, which further serve to absorb and then diffuse sound waves as they pass to the main filter.
The stand assembly comprises a horizontal bar onto which both the Reflexion Filter, and any standard fitting shock mount can be fixed. Both the microphone (in its shock mount) and the Reflexion Filter can then be moved both vertically and horizontally along the bar to obtain the optimum working position.
How does it work?
The various layers both absorb and diffuse the sound waves hitting them, so progressively less of the original source acoustic energy passes through each layer. This reduces the amount of energy hitting un-treated walls and other surfaces so there is less of the original source reflected back as unwanted room ambience to the mic. The Reflexion Filter also helps prevent any reflected sound reaching the back and sides of the mic. Its shape and size have been carefully tested to maximize absorption while keeping 'coloration' down to only around 1dB, and leaving the microphone's polar pattern unaffected.
In summary:
All in all, it's a very clever and desirable piece of kit. It allows you to record vocals, guitars etc with a 'drier' sound without having to have an acoustically treated room. It's portable. It uses state of the art materials. It works… and it's a fraction of the price of acoustically treating your studio environment!
Ever notice that people labelled eccentric are usually geniuses?
Old 04-11-2006
slidey's Avatar
slidey slidey is offline
Happy Legs Fingers Davis
slidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond reputeslidey has a reputation beyond repute
Wow
that was a neat description I 've got one on order & I'll probably have a double mattress at my back when I use the screen
on the other hand I might not (have a double mattress)
Ddude666 thank you very much for that
BOING!!!!!!!
G.F.C.G membership No# : 000 042
boingaroo aka wannabe drumber
Old 04-11-2006
gilwe gilwe is offline
Force of Nature
gilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these partsgilwe is infamous around these parts
I can see no point using it, you'll need good room acoustic facilities and noise attenuators anyway.
Old 04-11-2006
slidey's Avatar
the mattress or the reflexion filter
BOING!!!!!!!
Old 04-11-2006
COOLCAT's Avatar
COOLCAT COOLCAT is offline
2.5K Gold Member
COOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond reputeCOOLCAT has a reputation beyond repute
I was making one of these and signed up for a patent-pending...
the concept was for taking out the "room", especially the backside of the LDC's in crap drywall rooms.
Then I noticed there were others already out there.
Doesn't Auralex have a wedge or something too? Same concept.
This one looks nicer and they went much further with the 6 layers and panel approach.
as far as "working"... another tool in the studio?
My skeptisism is if the room is very small I don't see how its going to block much sound as its so far from the mic, has open top, open bottom?
if it's not happening in the room, it ain't gonna happen on tape.-HG
Old 04-11-2006
60's guy's Avatar
60's guy 60's guy is offline
9th most annoying poster
60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute
It might work in a pinch if your room environment isn't very good. It might also be useful for narration and voice-over work. Just a thought. Pretty stiff price though, for what it is.
Old 04-11-2006
Chip Evans Chip Evans is offline
Dave Clark Five
Chip Evans is on a distinguished road
I have used devices like this that were homemade and usually "temporary" in nature. It is really just a small proximity gobo placed on a stand. It's use would, in my opinion, be best used in a small, minimally treated room. This device, and others like it, will make more of a difference in your sound then you may think.
Chip Evans
Old 04-11-2006
Force of Nature
200 pounds are far more expensive than what I woiuld expect for this type of device.
Old 04-11-2006
slidey's Avatar
Thought
is there such a thing as a search engine that will take the product (in this case the SE RF) & look for the cheapest deal...........
if £200 is considered steep I wonder what it can be got for it's advertised in sound on sound at £229
BOING!!!!!!!
Old 04-11-2006
COOLCAT's Avatar
2.5K Gold Member
here's another angle, $50 Auralex expanders
  #12
Old 04-11-2006
Sloan's Avatar
Sloan Sloan is offline
Force of Nature
Sloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond repute
Has anyone here actually used those?
I was wondering how much they effect the sound.
sloanstewart.com
  #13
Old 04-11-2006
COOLCAT's Avatar
2.5K Gold Member
A DIY, mine was shaped like a amphitheatre, with foam inside the casing.I tried cardboard, plastic, box, rounded, square...all had pretty much the same effect. This is the only one I tried.
do they work? anything can change the sound of your mic.
same as a towel or your hands cupped around the mic, blankets, a corner of the room, foam, metal plates...etc.
I agree with what Chip Evans stated on this side of it... you'll hear it.
$200 seems kinda high imo, i'm with gilwe.
Imo, its kinda like a $200 multi-effect pedal patch that's called MARSHAL STACK. You have a $200 thing, instead of a Vocal booth or treated room.
now that I think of it, I finally searched for a different microphone that was uni-directional and required the sound to be close to get rid of my Drywall echo Crap-hole sound.
I never use my never patented DIY DEFLECTOR REFLECTOR MIC SHIELD ISOLATOR FOAM AMPHITHEATRE CARDBOARD PLASTIC SHIELD anymore.
Being open-design, I don't see how it prevents sound coming "into" the mic ?
The one I made was closer, had a top and bottom and took the room out more I would guess. It cost about $10 to make. More like the Auralex, but with the "amphitheatre" shaped housing.
damn..1000 orders already at NAMM $200 each...not bad at all.
Thats $200,000 approx!! It is very professional looking and appears well-built.
Much more materials & science and physics went into it, probably.
  #14
Old 04-12-2006
EdJames's Avatar
Senior Member
Even worse than that, in the UK the SE Electronics RF Reflexion Filter is £200, thats pushing $400!!! Cheapest I found it was £196.97 which is $345.84 plus delivery costs. Essentially, if I'm to buy this I wanna know if people think it'll be worth the money!
ED JAMES
  #15
Old 04-12-2006
immature
I have the code of a deal for it from Digital Village. I think it took the price down to £110. I'll see if i can find it..
  #16
Old 04-12-2006
slidey's Avatar
tell me quick I've not quite bought one yet
it comes friday on approval
I'm off to Digi Village
L8r
BOING!!!!!!!
  #17
Old 04-12-2006
slidey's Avatar
hmmmmmmmmmm you must have a really good relationship with the management
as £199 inc vat is what's advertised
£110 is a VERY NICE PRICE
curious curious curious
Slidey.....................
BOING!!!!!!!
  #18
Old 04-12-2006
immature
I cant find the code, but it was a special promo price at Sounds Expo. It was a show deal, but i asked them if i could pay this price another time as i couldnt pay there and then - so they gave me a code to use. The only problem is finding it...
I have a big bag full of catalogues from that show, but i cant remember where i put it. I'll do my best though.
  #19
Old 04-12-2006
slidey's Avatar
man you'd be the best dude on the planet
BOING!!!!!!!
  #20
Old 04-18-2006
slidey's Avatar
Bump
I've recieved it, tried it out with the trusty AKG solidtube & WOW
It does what it says on the tin.............price a bit steep at £180 but in the long run it would cost me more in mental health bills if I didn't have it
a great piece of kit
BOING!!!!!!!
  #21
Old 04-19-2006
immature
Good stuff mate, any chance of some clips? with and then without the filter?
  #22
Old 04-19-2006
slidey's Avatar
ahem when I get a PC that isn't steam driven LMAO (sorry dude it will get there honest I'm not a dinosaur )
BOING!!!!!!!
  #23
Old 05-10-2006
EdJames's Avatar
Senior Member
Did you ever find that code?
ED JAMES
the Karma chronicles... kidvybes Microphones 35 08-11-2006 09:04
Pop filter is filtering more than pops tone_aot Microphones 5 03-15-2006 22:28
Need an Audio Dust Filter? 12Kevin Other Equipment and Reviews 4 02-24-2005 15:41
SMD vs conventional electronics Rossi Microphones 6 11-27-2002 04:25
pop filter problem postalblue Microphones 5 02-21-2002 11:52
