vocal tuner sonar 5
why cant I find vocal tuner in sonar 5? I dont even see it mentioned in the manual.
People always seem to embrace the future then long for the past |
which version have you got? |
Do you have Producer or Studio? I found it's only in Producer. It is listed in the help section, under V-vocal. And there is a video on Sonars site showing some basic uses.
I won the internets...... |
I have producer
Oh , ok there it is. Wow looks complex! I looked in the manual but under vocals it only has vocal track, removing! I hate manuals. Great advise, I'll go to web and look at tutorial.
Thanks!
Have you looked at the big 600 page PDF manual you get with the software? I'm sure it's in there but I skipped it because I've only got Studio...
608 pages to be exact. Yes but it only listed vocal track ,removing page 330. I have found it with everyones help.I would never have looked there! Seems to be rather complex at first. I'll give it a whack.
I've messed with it before, but it didn't seem to do anything to my voice. I'm not sure if it's automatic or if you have to go in and edit each mistake. I watched the video, and they made it seem so easy, that even I could work it, but alas, I gave up after a few minutes.
Dogman, just go in there and drag a single note over to a different note and check out the difference. Manual fixes are pretty easy. Often all you need to do is nudge it over just a bit and it helps alot. Just be careful with the transitions between notes. Sometimes you've got to redraw them or at least tweak them a little to get it to sound natural after you nudge a note into key.
Some of my music |
#12
Is the Roland V-Vocal plugin worth the price of an upgrade from Sonar Studio 4? It seems to be the only thing I can see have a use for at the moment. I use my Sony SoundForge 7 pitch shift to adjust individual notes when I go a few cents flat or sharp. But the demo on the Roland plugin really looks like it could be useful in cleaning up phrasing etc. I guess I need some incentive to part with $250 for the upgrade.
#13
Guys...do u know if its possible to use the Roland V-Vocal plugin as a VST in Cubase? because i have both sonar and cubase, but i dominantly use cubase. and i dont want to use sonar just for the sake of v-vocal. so is it possible?
#14
Some of my music |
#15
I believe Autotune and Melodyne(?) do the same thing. |
#16
can i get that v-vocal in sonar 4 PE somehow or something like it?
#17
Autotune will work within Sonar. Melodyne is a standalone program that requires you to export the track, adjust it, and reimport it to Sonar. I believe both programs have demo versions available - although it would probably be cheaper to simply upgrade to Sonar 5. |
#18
#19
V-Vocal is explained (poorly in my opinion) on page 391. |
#20
All these graphical tuning stuff are way too time-consuming. I suggest you buy a copy of Melodyne. You will LOVE it. i use it all the time..to create vocal harmonies..fix up the tune(obviously) and so many other stuff. and its soooooooo much easier to use. you will never turn back to antares or v-vocal.
#21
How do I work autotune in sonar 4? I can figure out how to change one part to a specific pitch?
#22
Is there a better program i can use for vocal corrections?
#23
Auto tune and Melodyne are the two pitch correction programs that are available. They both require you to know what note you are supposed to be hitting and/or the key of the song. No matter what, you can't be that far off in pitch or the correction will sound wierd.
#24
#25
drathbun (and others): I bought Sonar 5 PE for the primary reason that they had V-Vocal. While it's useful occasionally, I think in retrospect I would've rather bought Cubase SX3. V-Vocal is not a very transparent shifter - you can hear some pretty serious phasing in it on some voices, especially if they're breathy or airy. It sounds like MP3 compression in your song, which is not so attractive. I don't know anything about Melodyne, but I'm certainly curious. Anyway, bottom line, if V-Vocal is the only reason you're thinking about getting Sonar 5 PE... think some more, because I don't think it's worth the extra $$.
| Sonar: Using the Tuner | Qwerty | Cakewalk / Sonar Forum | 9 | 09-23-2004 20:15 |
| Upgrade: SONAR 3 Studio Edition $79 bucks | RAPD | Cakewalk / Sonar Forum | 15 | 12-22-2003 19:03 |
| Music - please rip apart | Greenshoe | MP3 Mixing Clinic | 20 | 07-29-2003 00:49 |
| Encoding Sonar MP3s for free | garrigus | Cakewalk / Sonar Forum | 2 | 11-12-2002 18:47 |
| Check this out Sonar users... | tubedude | Cakewalk / Sonar Forum | 5 | 08-10-2001 07:52 |
