Old 04-08-2006
coolsoundman coolsoundman is offline
Senior Member
coolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond repute
Reducing 24 bit to 16 bit?
Anyone know how to reduce the recording from 24bit/96000? I recently recorded a song using the 24/96 bit and now when I do playback and mix, I get a lot of clips an pops. Not only that, my cpu meter goes into the red and sometimes I get dropout's. Anyone know how I could reduce the recording from 24 to 16?
Old 04-08-2006
Albertm's Avatar
Albertm Albertm is offline
Dedicated Member
Albertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond repute
In Sonar 5 you go to Options/Global/Audio and switch there. By instructions you should be able to switch at any time from one to another.
Old 04-08-2006
Senior Member
I use sonar 4pe.
Old 04-13-2006
bobs88s bobs88s is offline
Newbie
bobs88s is on a distinguished road
Another possibility will be to ease the workload on your processor and bounce some tracks, increase your buffer size, increase latency - or all 3 This way you can retain the high resolution of your recording for the mixing stage, then dither it down to 16/44.1 for exporting and burning to a CD.
Just a thought.
Bob
Old 04-13-2006
fraserhutch's Avatar
fraserhutch fraserhutch is offline
Flypaper for freaks
fraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond repute
However, you should note that that will not automatically change the bit depth of your tracks, just how they're interpreted by Sonar. Any existing tracks in the higher bit depth will need to be manually converted to the lower depth.
At least that is as best I recall.
The fact that no one understands you doesn't mean you're an artist...
Old 04-14-2006
TimOBrien TimOBrien is offline
2.5K Gold Member
TimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond repute
FREE tool:
http://www.voxengo.com/product/r8brain/
Old 04-15-2006
maximum octopus maximum octopus is offline
Senior Member
maximum octopus has a reputation beyond reputemaximum octopus has a reputation beyond reputemaximum octopus has a reputation beyond reputemaximum octopus has a reputation beyond reputemaximum octopus has a reputation beyond reputemaximum octopus has a reputation beyond reputemaximum octopus has a reputation beyond reputemaximum octopus has a reputation beyond reputemaximum octopus has a reputation beyond reputemaximum octopus has a reputation beyond reputemaximum octopus has a reputation beyond repute
First, I have a question. Are you doing the playback and mixing in Sonar? Do you have a 24/96 capable sound card?
Sometimes there is a sample rate conflict that can make things sound like absolute ass.
Also, do you have anything running in the background? Anti-virus software?
Wireless network? Anything running in the background can put a big strain on things regardless of what version you may be using.
Experiment. Try disabling any effects plugins that you may have running and see if it still does it.
Hope this helps.
Audio Driver Bit Depth (24 bit) johnnypraze Digital Recording & Computers 2 08-17-2004 18:29
16 bit vs. 24 bit Question savedbygrace Newbies 5 02-19-2003 07:13
Final words about increase in bit depth/sample rate? MatsD Mixing / Mastering 26 03-13-2002 10:14
when it REALLY comes down to it...(yes, more 16-bit vs 24-bit) shackrock Digital Recording & Computers 36 03-10-2002 20:23
