Good metal / hardcore kick sound.
I keep trying to post something and it won't let me, wtf?
Take care, Adam. EDIT; I changed the title but it wasn't letting me post. Something similar too this bands recording: http://profile.myspace.com/index.cfm...iendID=1637317 Mic placement techniques are what i'm looking for. The bass drump is 22x18. That's about all I know though. Should I take the front head off, keep it on, put the mic close to the beater, far away, blankets, no blankets? I'll be using an AKG D112. Any help is greatly appreciated. Thank you. Take care, Adam. Last edited by inmyheartx; 04-06-2006 at 22:10.. |
It let you post that...
http://i65.photobucket.com/albums/h2...GFCGjester.jpg Quote:
Take care, Adam. |
I wouldn't be suprised if that kick is triggered. Other than that, I would say concentrate the most on tuning the kick well to get it to sound as close as you can get. Use mic placement to your advantage. Get the mic close to the beater so that you can get lots of attack and click.
Check out my band!! www.myspace.com/darkvelvetlaughter GFCG Membership No:000 019 |
I once read in sound on sound that if you want more click from a bass drum you can tape a old credit card(or something similar) to the bass drum skin where the beater hits the skin.I have never try'd this but im pretty sure the guys at sound on sound know what they are talking about.
thanks.
I am in your house |
i use two mics, probably your d112 out to get the boom and then a 57 or another drum mic pointed down at your beater in the same direction as your overheads, then flip the phase of the outer kick mic.its nice so you can eq the beater mic a ton and then still have a good sounding outer mic to mix in with it.
i really wanna try that credit card thing sometime though... good luck!
tascam 1804 self-built amd 4000+ system gateway m285-e core 2 duo tablet pc m audio sp-5b's reaper v1.8x |
i too have been reaching for the punch kick sound. I am going to try the credit card trick. I get pretty good results now. I use a res head with a 5" hole (evans). Stick a beta52 into the hole about mid shell. Phase reverse position toward the beater. The phase reverse was like nite and day (boom/punch).
hope the helps |
Take care, Adam. |
Make sure you're using a hard beater, plastic or wood. Nothing will make a felt beater click, not even a credit card. I'm seen people duct tape a sheet metal disc to the head as well, btw.
I wish my lawn was Emo so it'd cut itself. |
When I'm going for a slappy kick, i use an AKG D112 inside the kick close to the beater. And an Octava MC-012 on the outside of the front head about 3 inches from the beater, pointed directly at the beater. Reverse the phase, and you're good to go.
Conditioned to self interest with emotion locked away.....if that's what they call normal then I'd rather be insane. |
I'd try to get the mic within about 6 inches of where the beater hits the head on the inside of the drum. Face it slightly away from the hihat. Then after it's recorded crank it up at about 3khz til you get the click you want.
#12
Take care, Adam. |
#13
Take care, Adam. |
#14
that's weird, that band has been talking to me about joining their band, haha.
i'd say that kick is definitely triggered. |
#15
Take care, Adam. |
#16
#17
#19
Clickmungous Slidey
BOING!!!!!!! G.F.C.G membership No# : 000 042 boingaroo aka wannabe drumber |
#20
![]() Last edited by Sonixx; 04-09-2006 at 11:59.. |
#21
you could also try taking ajunk front head cutting a hole in it, almost cutting the whole head. leave about 2 inches around the sides. tune the batter head really loose, right before it wrinkles. lay a pillow down just touching the batter head, the put a concrete block ontop of the pillow. put the mic in 6-8 inches off the batter head off axis pointing at the beater. then cover the front of the bass drum with a moving blanket or a couple heavy blancket. i have had very good luck doing this, hope it helps.
#22
Take care, Adam. |
#23
it sounds like they have phased it.
#24
the only clips I got is holding my mics in place ![]()
| OK... Forget it!!! Post here any E-Magic Product Forums on OTHER websites. | pisces7378 | Digital Recording & Computers | 5 | 02-25-2002 01:13 |
