Normalizing In Sonar 4 Producer
I would like to nomalize a five track recording, but when I select all, then process audio, then normalize, Sonar only normalizes the first and last tracks. Can anyone assist me with this?
are these five tracks on individual track rows in sonar? is there a reason you are doing a select all?
have you already figured out the tracks level relative to each other and now just want to raise them to the peak relative level, or do you want to raise each track such that its peak reaches digital 0? finally, are you normalizing because you are going to send your track to a mastering house or because you don't want to lose bits, or are you normalizing because you are a purist who never uses multi-band compression and maximizers (limiters) to make your mixes louder? |
It's now called 'Abnormalizing' -which more truely reflects the nature of the proces.
I'd be surprised if you could do several 'process audio' at once. Isn't each a separate function?
It could also be that the 3 in the middle already have a peak or two that hit zero, if so normalizing will have no effect on them.
If a kick drum gets hit in the forest and no one is there to mic it, does it make a sound? |
| Sonar 5 Producer errors fixes | jmorris | Cakewalk / Sonar Forum | 1 | 03-04-2006 00:51 |
| Sonar Producer Edition | Audiohead27 | Cakewalk / Sonar Forum | 1 | 02-15-2006 12:15 |
| Finally Upgraded to Sonar 4 Producer | DigitalDon | Cakewalk / Sonar Forum | 11 | 06-12-2005 00:25 |
| Sonar 3 Producer Edition (making final mix louder) | trendkill918 | Cakewalk / Sonar Forum | 5 | 10-07-2004 20:10 |
| Sonar Producer Edition HELP! | colourblind1 | Cakewalk / Sonar Forum | 6 | 03-23-2004 15:31 |
