Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 04-02-2006
sfcphilip sfcphilip is offline
Newbie
sfcphilip is on a distinguished road
midi output selector in PT le 7
Hello,
All I am trying to do is be able to select Bus 1-2 stereo on the MIDI output selector. I created an audio track and I am trying to Bus the signal from the MIDI track to the input of the audio track so that I can hear the audio. It was working about an hour ago and now I can't do it. The only selections I get are predefined and the actual instrument that I am using. What happened? By the way, I am using Pro Tools le 7. Thanks.
Old 04-02-2006
sixways sixways is offline
Force of Nature
sixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond repute
Set your output of your midi channel to (for example) Bus 15-16. Set the input of your audio channel to Bus 15-16. Raise both faders, should work.
6
Old 04-02-2006
Newbie
That's the problem. I am not given a choice of Buses to select.
Old 04-07-2006
bassntreble bassntreble is offline
Newbie
bassntreble is on a distinguished road
Hey SFCPhilip,
set the output of the midi channel to the device you are trying to trigger.
the midi device should either be a Virtual Instrument inserted on an aux track or a hardware instrument that is patched into your audio interface.
In the case of a hardware instrument, make sure the aux track's input field is set to the inputs the hardware is connected to, eg. if you have the stereo outputs of a Triton connected to inputs 7+8 of a Digi002, set the input for the Aux track to input 7-8.
In protools 7, using an instrument track is a much easier way to go. at the risk of sounding redundant, if you haven't already, check out my video tutorial.
http://audiotactix.com/tutorials.html
I'll have the rest of them up over the weekend
Completely MIDI CONFIG Illiterate Outhabox MIDI Mania 4 03-10-2006 10:43
Stuttering MIDI Output Pulseczar Digital Recording & Computers 2 09-26-2004 17:20
expansion on the midi problem Ebicaneezer Cakewalk / Sonar Forum 7 04-11-2003 13:58
Sonar not recognizing Midi Output Pryapus MIDI Mania 3 04-04-2003 14:46
Here is a solution for Midi Sync with a VR800 as the Master using Cakewalk! Rish Fostex Forum 0 12-12-2000 13:32
