Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 03-30-2006
Abstrak Abstrak is offline
Newbie
Abstrak is on a distinguished road
New to this forum, FL Studio MIDI to REASON 3.0
Well as my title says im new, and that I have questions about reason
My first question is about midi.
I started off with fruityloops(now FL Studio) and I want to make a transition to Reason 3.0.
I started using both programs for about a couples months, just to see if i really wanted to switch, and i did.
Well, I wanted to start using reason, but i didnt want to leave me FLP files in the dust.
I tried turning the flp song into a midi file, then importing it into reason, but I dont know what program to connect the sounds to.
I dont know if it is the NN-XT or redrum. Im hoping to be able to put them on REDRUM.
Well thanx alot for the replies
Old 03-31-2006
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
If you could combine your three questions into one it would save energy --- yours, mine and ours.
...now in HD.
Old 04-01-2006
Mahem Mahem is offline
Newbie
Mahem has a reputation beyond reputeMahem has a reputation beyond reputeMahem has a reputation beyond reputeMahem has a reputation beyond reputeMahem has a reputation beyond reputeMahem has a reputation beyond reputeMahem has a reputation beyond reputeMahem has a reputation beyond reputeMahem has a reputation beyond reputeMahem has a reputation beyond reputeMahem has a reputation beyond repute
lol Why in the hell would you transition from FL to Reason? Have you seen FL6? I dont think Reason can compare...
Old 04-01-2006
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
Ok, you need a midi primer first:
http://www.tweakheadz.com/how_to_get...with_midi.html
After you get a handle on that, this is what you need to do:
In FL, make sure each track is on its own midi channel (there has to be a way to do this, check your help file) and export it as a midi file. In reason, start a blank project and go to file/import/midi file and find the file you exported. It should now open a bunch of tracks in the sequencer window at the bottom, those tracks should correspond to the FL tracks except there will be no sound generators attach so you will need to assign reason instruments to those tracks (the little pull down menu on each track). Drum= redrum, synth=subtractor, samples=NNtx etc
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 04-01-2006
studiomaster's Avatar
studiomaster studiomaster is offline
MachWave
studiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond reputestudiomaster has a reputation beyond repute
You have to learn the basics first, my friend. Redrum is a virtual drum computer and does not compensate with MIDI. And plus, why would you want to turn the FLP song into MIDI files and use it in Reason? Why not just use Reason for the whole composition? After all, Reason is a 100% better software than FL, though it has an extensive learning curve.
Old 04-01-2006
what does that mean exactly?
Old 04-01-2006
Info you can use...
I have both.
Reason is better.
And altitude 909, I'm not quite sure what this means either:
Maybe we could ask him, but I don't think it would do any good...
...now in HD.
Old 04-02-2006
sixways sixways is offline
Force of Nature
sixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond reputesixways has a reputation beyond repute
FL6 must be capable of a hell of alot more than I thought it was if Reason can't compare.
6
Oxygen 8 and Reason 3.0 Motioneso MIDI Mania 5 03-20-2006 17:16
Korg Triton into Digi 002 Rack cayotic MIDI Mania 20 06-26-2005 19:49
Midi track with Sonar & Audigy’s Interface?? carlosfl Cakewalk / Sonar Forum 6 06-25-2005 11:16
The wrist bone is connected to the hand bone; help with MIDI and USB concepts/setup f. lai MIDI Mania 4 07-13-2002 13:55
Here is a solution for Midi Sync with a VR800 as the Master using Cakewalk! Rish Fostex Forum 0 12-12-2000 13:32
