Old 03-29-2006
souwalker souwalker is offline
Newbie
souwalker is on a distinguished road
Power Mixer/Guitar/Recording
Hi All
My other guitar partner and myself are about to get the Behringer PMH3000 powered mixer. For recording purposes, we 've done this via our current power mixer PMH2000 with pretty good results.
My question is, in the user manual (PMH3000), there is a picture of a bass & electric guitar hooked up to a V-Amp and the v-amp connected to the mic line in for recording of the bass and guitars.
We both have the Boss ME50 Multi Effects box. There is a combo phone/line out connection at the back. Could we use the ME50 instead of the v-amp? The ME50 line out to the power mixers line in per the manual?
What we did in the past was to mic the amps but the results were not that good. If we could use the ME50, we could avoid more mics, cables etc...
Thanks
Patrick
Old 03-29-2006
gecko zzed's Avatar
gecko zzed gecko zzed is offline
audio illusion
gecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond repute
The answer is yes. The Boss can go into one of the mixer's channels, most likely as a line in. If the Boss has an XLR out, then that suggest mike level output which could go into a channel as a mike input.
Old 03-29-2006
Newbie
Thanks gecko.
The ME50 do not have xlr out, just line out. From the mixer's manual, the V-amp goes into the 3rd or 4th line in underneath the XLR in, so I am concluding that I should also do this? is this method for the'gain'?
Rgds
Pat
Old 03-29-2006
gecko zzed's Avatar
audio illusion
The ME50, then, has 1/4" output, and you would normally use a guitar lead to go from this to a guitar amp, right?
Instead of going into the amp, you just plug the guitar cable into the 1/4" line-in socket on a channel of the mixer.
You may need to adjust the gain control on the channel, depending on the strength of the signal being delivered by the ME50.
I'm not sure what you are actually asking when you say "V-amp goes into the 3rd or 4th line in underneath the XLR in, so I am concluding that I should also do this? is this method for the'gain'?" because I don't have that mixer nor its manual. However, that doesn't matter, because the principle is the same.
Old 03-29-2006
daav's Avatar
daav daav is offline
Flailing up a storm.
daav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond reputedaav has a reputation beyond repute
to answer as simply as possible, yes the ME-50 will replace the v-amp in your example.
The effects unit is functioning as a preamp, you can adjust the volume out to a level that sounds and records well after it gets through the mixer.
Daav
Old 03-29-2006
Newbie
Thanks to all.
Just to make it clear for myself..
The ME50 has an output jack which we plug via cable to the amp.
The ME50 also have a combo phone/line out plug, which looking at the ME50's manual, shows to go to the mixer.
Do I use the output or the line out?
Thanks
Pat
Old 03-30-2006
irishfolker's Avatar
irishfolker irishfolker is offline
Structural Member
irishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond reputeirishfolker has a reputation beyond repute
Use the line out.
Old 03-30-2006
gecko zzed's Avatar
audio illusion
try line out first
but it doesn't matter
there is no harm in trying both and seeing which gives the best results
Old 08-20-2006
dkelley's Avatar
dkelley dkelley is offline
Dedicated Member
dkelley has a reputation beyond reputedkelley has a reputation beyond reputedkelley has a reputation beyond reputedkelley has a reputation beyond reputedkelley has a reputation beyond reputedkelley has a reputation beyond reputedkelley has a reputation beyond reputedkelley has a reputation beyond reputedkelley has a reputation beyond reputedkelley has a reputation beyond reputedkelley has a reputation beyond repute
except one thing not being mentioned, the me-50 doesn't have an amp/speaker simulator through the line outs, but it does through the headphone output. you might want to use the headphone output (at lowish volume) to get the best tone.
Don Kelley
Owner/Operator/Engineer/Session Player for
doubletakerecording
"Give me a gig!!" ~~~ Jaco Pastorius
help! power supply producing a hum. sproutrecording The Rack 4 11-24-2004 11:38
All the World's Tube Microphones PART ONE Bambi Busboom Microphones 2 08-15-2004 04:02
pulling power tubes ----> 50% power gusfinley Guitars and Basses 1 06-24-2004 08:21
What is the noise floor on your Delta? canada-paul Digital Recording & Computers 30 05-27-2003 06:59
Help!! - Double Phantom Power ?? Carlos Microphones 13 05-26-2000 09:42
