Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 03-28-2006
Humbucker's Avatar
Humbucker Humbucker is offline
Senior Member
Humbucker has a reputation beyond reputeHumbucker has a reputation beyond reputeHumbucker has a reputation beyond reputeHumbucker has a reputation beyond reputeHumbucker has a reputation beyond reputeHumbucker has a reputation beyond reputeHumbucker has a reputation beyond reputeHumbucker has a reputation beyond reputeHumbucker has a reputation beyond reputeHumbucker has a reputation beyond reputeHumbucker has a reputation beyond repute
Clipping after limiting
I've just finished mixing an instrumental track I'm working on and to add a bit of polish(I certainly wouldn't call it mastering hehe) I EQ'd the final mix a little, compressed it a little and put it through the Kjaeurhus Master Limiter aswell as adding dithering using the Cubase UV22. I'm just a little confused as to how to tell if it is 'over' in terms of peaks. I know obviously you should hear some distortion but I don't hear that. Basically I just added a couple of decibels to it with the Limiter, but how do I know how far I can push it? There is a meter on the Classic Master Limiter but it was going nowhere near the red on there, however when bringing it into T-Racks(purely out of interest to see the level) it said it was going over. Also in Cubase it was going way into the red. Can I basically push it as far as I want, but of course the further I push it the more it is gonna be 'squashed' as to limit the peaks it needs to compress the signal? I'm thinking it's a case of trusting your ears, but I know there are far more experienced ears out there than mine so I don't necassarily trust my own 100%. I guess Im basically asking for a summarised explanation of limiting. Here's the track I'm talking about, like I said it has +2b on top of it with the Limiter. Can I take it higher or should I just leave it the way it is? Apologies for the nieve undercurrent to my questions, but you gotta ask Here's the track:-
http://www.lightningmp3.com/live/file.php?fid=3188
Old 03-28-2006
TheDewd's Avatar
TheDewd TheDewd is offline
Dedicated Member
TheDewd is infamous around these partsTheDewd is infamous around these partsTheDewd is infamous around these partsTheDewd is infamous around these partsTheDewd is infamous around these partsTheDewd is infamous around these partsTheDewd is infamous around these partsTheDewd is infamous around these partsTheDewd is infamous around these partsTheDewd is infamous around these partsTheDewd is infamous around these parts
You have room to push it much more.
But there are some problems with your mix...the worst being that the bass is MUCH too loud. This doesn't help if you want to push the levels to the top.
Old 03-28-2006
Humbucker's Avatar
Senior Member
Argghhh the balance in volume between the bass and the drums has been the main thing I've struggled on with the mix. Today I turned the drums down a little and the bass up a little. To my ears the bass level sounds OK, but admittedly I'm not listening through monitors or anything, just through a Hi-fi. But great to know I can push the levels some more in terms of the final mix - many thanks.
Old 03-28-2006
TheDewd's Avatar
Dedicated Member
Yep, but lower the bass some before attempting to push too much, since low frequencies eat up a lot!
Old 03-28-2006
Humbucker's Avatar
Senior Member
Yeah, definetely.
Old 03-28-2006
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
In most brickwall limiter plugins you can set the maximum level. That can be set anywhere from -.1 to -.5 and you'll be pretty safe from overshoots. I usually set it to -.3 on my stuff.
http://www.misterpotts.com
Old 03-29-2006
Humbucker's Avatar
Senior Member
OK here's my final mix of this piece:-
http://www.lightningmp3.com/live/file.php?fid=3195
The limiting definetely added a decent amount of volume - the software(Classic Master Limiter) said it wasn't going over and it sounds fine so I assume all is well. Would appreciate some more experienced ears taking a listen though.
Old 03-29-2006
Dogman's Avatar
Dogman Dogman is offline
Campeón de la Internet
Dogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond repute
I think it sounds pretty decent man.....
I won the internets......
Old 03-29-2006
Humbucker's Avatar
Senior Member
Cool - thanks.
Old 03-29-2006
The only thing you might want to consider is treating the guitar solo at the beginning differently from the rest of the song once the drums come in. The reason being that when you limit you bring everything up in volume, and I felt the sound of the fingers sliding on the guitar was a bit too much. Not hugely too much, but it kind of got in the way a little bit, at least for me. Once the beat kicks in I thought the limiting was fine.
Old 03-29-2006
Humbucker's Avatar
Senior Member
Thanks for listening SonicAlbert - yeah I agree about the bass in the beginning, aswell as the limiting I had to boost the high end EQ a little bit so that definetely had an affect on that. When I recorded the bass I forgot to turn on the lo-cut filter on my DMP3, which meant I had to EQ more than normal to correct the boominess. I'll definetely know for the future though. Thanks again.
  #12
Old 03-29-2006
TheDewd's Avatar
Dedicated Member
You didn't do much to the overall loudness. Limit the shit out of that song!
You can limit much more than this. It's not competitive enough.
You have to peak some red on the limiter!
IMHO, the Classic Limiter is bad for getting high levels. Sorry, I can't recommend anything better that's free, but I know it sounds ugly when you try to hit reasonable levels (about -8 dB RMS).
  #13
Old 03-29-2006
Actually, I thought the amount of limiting was fine, once the song got into the part with drums. My meters were almost all the way to the top, as far as volume. And the song still sounds natural. There's no reason every song has to have *all* the dynamic range crunched out of it.
  #14
Old 03-29-2006
TheDewd's Avatar
Dedicated Member
I thought like that and stayed away from the crunching until I found out that most (if not all) of the rock bands I like get their "crunchy gritty" sound by limiting the crap out of the mix.
Furthermore, being competitive is so important in today's rock music....
clipping question cpc Newbies 34 02-22-2006 15:25
DITHERING...A few questions... RAMI Mixing / Mastering 32 11-07-2005 11:30
trying to understanding clipping guttadaj Cakewalk / Sonar Forum 5 12-15-2003 12:09
How can I get LOUD tracks using Compression and limiting without clipping? FattMusiek Cool Edit Pro / Adobe Audition Forum 22 05-23-2003 13:43
