clean audio disc, am I right?
This tool only removes the unused audio tracks right? From what I read in the manual I am assuming it will remove tracks/files no longer used like deleted tracks, unused overdubs and punch in. Am I right? It says( in the manual) it will remove items from clip board. I had out of memory on audio disc message come up.
People always seem to embrace the future then long for the past |
If you are using Per Project Audio folders you are better off using the latest Cakewalk Audio Finder Tool - CWAF v3.5 (I think), which is more intelligent about how it cleans up the drive/s.
Freebie download from the Cakewalk website or it is on the Sonar v5 CD. Ciao, Q.
<insert something witty here> |
Thanks,Jim
From memory the Clean Audio Disk command isn't as aware of Per Project Audio folders as CWAF is.
From an operational perspective, if you have .CWPs and audio files in multiple locations, CWAF is just a more elegant solution. So said, I haven't even touched the Clean Audio Disk command since v3 -- I have used CWAF ever since, so some of the functionality may have changed with later releases. As with any cleanup command BACK UP FIRST!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Q.
| Audio to PC MIDI Sync | mark4man | Fostex Forum | 0 | 07-21-2002 08:45 |
| clean audio disk not working?? | Sydney | Cakewalk / Sonar Forum | 3 | 05-12-2002 20:58 |
| N-Tracks and Audio Buddy questions | smalltowner | Newbies | 3 | 12-20-2001 11:30 |
| Mastering disc with audio and data for mass replication | Shot | Mixing / Mastering | 2 | 07-12-2001 12:14 |
| PC DAW Digest | TAE | Digital Recording & Computers | 0 | 11-25-2000 09:03 |
