Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 03-27-2006
violindave violindave is offline
Newbie
violindave is on a distinguished road
help needed:Kurzweil KSP-8+Samplitude+Lynx
Trying to go into KSP-8 for effects from Samplitude via LynxTwo ADAT and back into Samplitude.
I have signal showing up in the output mixer of the Lynx. I have signal showing up on the meter stage of the KSP-8, but nothing coming back in to Samplitude.
I've tried to figure it out with the manual and it's over my head.
I'm trying to send tracks out [between one and eight at a time] digitally from Samplitude via the Lynx/ADAT into the KSP-8. Then back into the KSP-8 and record the effected tracks as new tracks in Samplitude
I would be extremely grateful if someone understands this setup and can walk me through it in simple step by step fashion.
I think I need someone to walk me through each stage so I have it setup right at each point:
settings in Samplitude
settings in the Lynx mixer
settings in the KSP-8
I'm pretty sure I have Samplitude right but could even be wrong there.
cheers
Dave
Old 03-27-2006
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
Your studio configuration in the KSP8 is probably not right. Make sure you have the signal flowing to the correct outputs.
http://www.misterpotts.com
Old 03-27-2006
Newbie
I don't know how to change the signal flow in KSP-8.
I see signal at the output meters, but none coming back to Lynx or Samp
where do I make that change. In master config there's no option I see to change it. input 1 goes to output 1.
cheers
Dave
Old 03-27-2006
If you see the signal on the KSP8 output meters, then it's outputting signal. Check your settings on your Lynx or in Samplitude. It's probably something very simple, a routing thing or channels that have to be enabled.
Old 03-30-2006
Newbie
Got it fixed
1. wasn't hooked up right
2. lynx mixer and Samplitude play and record channels not set right
cheers
dave
Samplitude with E-MU 1212M David Hughes Digital Recording & Computers 14 03-26-2005 03:26
Just got the Lynx II !!! Rev E Microphones 71 08-23-2004 18:15
Lynx or RME for recording classical instruments Uno Digital Recording & Computers 11 03-12-2004 10:02
What happened to samplitude??????? Havoc Digital Recording & Computers 3 02-24-2002 12:33
