what's the deal with linear phase EQ?
I keep hearing everyone rave about how sweet linear phase EQ is, but everytime I use it it just sucks some of the depth out of my mix, even 1db or less makes a noticeable difference. I strap on a regular old EQ with the same settings and most of the depth that gets lost with the linear phase EQ is still there? To my ears it makes things sound blurry. Am I missing something?
I have at times tried the waves linear eq and voxengo curve eq. my reference normal eq was hydratone. Why do you guys like linear phase EQ and for what?
Be true, gentle warrior. Stay with me through the night, my fine stallion, you incredible and powerful beast. Wild Hogan Recording |
From Universal Audio's WebZine:
[Linear phase] delay leads to advantages and disadvantages, depending on the situation. The biggest advantage is gained in filterbank applications, where a signal is split into frequency bands for separate processing, and recombined later. If a filterbank is made to be linear phase, it can be completely transparent as long as no modifications are made to the signal while it is split into separate bands. An application for this may be a de-esser which is being used to limit occasional sibilance. If the de-esser is made with a linear-phase filterbank, it can be made to be absolutely transparent except during those instants when the de-esser is active, reducing sibilance. On the other hand, if the filterbank is not linear-phase, then anything sent through the processor will incur phase distortion all the time, even when no de-essing is taking place. So for transparency in a filterbank, the linear phase property is valuable. For EQ applications, linear-phase filters will have different properties than their most commonplace counterparts, minimum-phase equalizers, but the advantage is not as clear-cut. Because linear-phase filters delay all frequencies by the same amount, the overall latency for a linear-phase filter will be higher than for its minimum-phase counterpart. Minimum-phase filters, on the other hand, have the least latency for a given magnitude response. This means that linear-phase equalizers can be unsuitable for real-time operation, or for operation within a feedback loop. G. |
That makes sense. A lot of people seem to be using it on an entire mix, for "mastering" purposes or whatever, but I'm just not hearing it for some reason. For de-essing I generally highlight only the offending spots and use the de-esser
there instead of the entire track anyway, which is time consuming but I think it sounds better.
| waves linear phase eq | djclueveli | Mixing / Mastering | 8 | 02-04-2006 14:58 |
| DIY M3500 phase switch mod | JerAy | Analog Only | 9 | 09-26-2005 09:50 |
| The 3-to-1 rule - misunderstood? | Jakob_v | Recording Techniques | 10 | 08-17-2005 09:02 |
| Phase problems and their corrections... | ambi | Recording Techniques | 4 | 10-07-2002 10:04 |
| Phase problems | inhousejohn | Recording Techniques | 3 | 08-16-2002 09:09 |
