Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 03-26-2006
Creamyapples1's Avatar
Creamyapples1 Creamyapples1 is offline
www.murphycabs.com
Creamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond reputeCreamyapples1 has a reputation beyond repute
Amp Noise: (now with sound clip)
I've had my Fender amp for about a year now. I've recently moved to a new place and I've notice a little more "hum" or noise from my amp than what I've experienced in the past. I was playing around today and noticed when the amp was on, but nothing was plugged intot he input jack, the amp is pretty much silent, when I plug a cord into it I get the noise, straight to guitar, still the noise, tried different guitars, noise. Just enough to be annoying, am I experiencing grounding issues where the amp is plugged in or have I just not cared enough to notice in the past? I was wondering if anyone would have any advice, suggestions, tips, tricks, the usual. Thanks guys!
Kevin - www.icanquitsmoking.org
The Small Business Workshop
My Generic Crap
The Murphy Cabinet Company
Custom Hardwood Amplifier & Speaker Cabinets
Old 03-26-2006
jaykeMURD's Avatar
jaykeMURD jaykeMURD is offline
Chocolate Rain
jaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond reputejaykeMURD has a reputation beyond repute
I've been through the "perils" of determining what causes that hum/hiss. Most commonly it's the instrument itself (input jack, wiring). So first, check the guitar(s). Next, carefully examine the 1/4 cord or cords for nicks, breaks, tears, lumps anything like that. A lower quality cable can ad some hiss and "dirt", but not a lot. The biggest source is usually what is called "line noise" or "power line noise". That stuff gets complicated, but somehow, somewhere, a wire inside OR outside of your house was wired badly/impoperly and will contibute to the noise. This can be solved by adding a "power" or line conditioner, often used for sensitive electrical equipment (hospital computers, mainframes). You plug one of these puppies into your basic wall outlet, and then plug in what you want to. I use on for my computer and guitar amp and it make a GIGANTIC difference in AC line noise and power fluctiations. There are different ratings, capacities, and such. A few minutes on Google will give you a good idea.
-Of course, this is just my solution. It worked for me!
Old 03-26-2006
joro's Avatar
joro joro is offline
I like pie.......and cake
Location: Clowns to the left of me...Jokers to the right....Here I am....
joro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond reputejoro has a reputation beyond repute
yup....sounds like it could be a ground...
is it a tube amp?
if so....
It might be the pre-amp tube...
Old 03-26-2006
Henry Mars Henry Mars is offline
Senior Member
Henry Mars has a reputation beyond reputeHenry Mars has a reputation beyond reputeHenry Mars has a reputation beyond reputeHenry Mars has a reputation beyond reputeHenry Mars has a reputation beyond reputeHenry Mars has a reputation beyond reputeHenry Mars has a reputation beyond reputeHenry Mars has a reputation beyond reputeHenry Mars has a reputation beyond reputeHenry Mars has a reputation beyond reputeHenry Mars has a reputation beyond repute
Certain types of lighting can (will) cause radiated noise ( hard to cure) and line noise which is easier to cure with a line conditioner. Line conditioners usually kill about 90 % of the time.
Old 03-26-2006
andycerrone's Avatar
andycerrone andycerrone is offline
Banned
andycerrone has a reputation beyond reputeandycerrone has a reputation beyond reputeandycerrone has a reputation beyond reputeandycerrone has a reputation beyond reputeandycerrone has a reputation beyond reputeandycerrone has a reputation beyond reputeandycerrone has a reputation beyond reputeandycerrone has a reputation beyond reputeandycerrone has a reputation beyond reputeandycerrone has a reputation beyond reputeandycerrone has a reputation beyond repute
Also, is there a tv or computer close to where you are when you play guitar? Many times that will cause the amp to hum.
Old 03-26-2006
www.murphycabs.com
I'll see if I can record some of the noise later today, the amp is fine if nothing is plugged into it, but as soon as I plug something in, there is an audible change. This happens with computers and lights on or off. I didn't have the problem until I moved in here, at my old house it was fine with the same guitars. I also tried 23423423 different cables, all witht he same results.
My Generic Crap
Old 03-26-2006
songwritten's Avatar
songwritten songwritten is offline
Senior Member
songwritten has a reputation beyond reputesongwritten has a reputation beyond reputesongwritten has a reputation beyond reputesongwritten has a reputation beyond reputesongwritten has a reputation beyond reputesongwritten has a reputation beyond reputesongwritten has a reputation beyond reputesongwritten has a reputation beyond reputesongwritten has a reputation beyond reputesongwritten has a reputation beyond reputesongwritten has a reputation beyond repute
"I also tried 23423423 different cables, all witht he same results."
Better double check that cable
I'm thinking it's where you are plugged in. Try different outlets in your house, a power conditioner is a great idea.
I like to write songs.
Old 03-26-2006
www.murphycabs.com
http://www.soundclick.com/bands/page...?bandID=423983
It's the one titled Amp Noise Test, read the description before playing. I did try some different outlets around the room and in a few others, it's pretty much the same thing.
My Generic Crap
Old 03-27-2006
www.murphycabs.com
bump bump bumpbumpbump bump bump
My Generic Crap
Old 03-27-2006
legionserial's Avatar
legionserial legionserial is offline
Dead
legionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond repute
Does the hum go away if you touch the metalwork on your guitar?
"Introduce a little anarchy. Upset the established order, and everything becomes chaos. I'm an agent of chaos.
Oh, and you know the thing about chaos? It's fair..."
Old 03-27-2006
www.murphycabs.com
no, I'm about to just say screw it and not even worry about it anymore lol
My Generic Crap
  #12
Old 03-27-2006
travelin travis travelin travis is offline
Banned
travelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond repute
does the noise change if you move around the room or change the angle of the guitar in respect to the amp? is a crt computer monitor on close by?
you never said if the amp is tube, solid state, or digital. digital amps are prone to noise with dirty power.
i'd REALLY inspect your guitar cable well too.
  #13
Old 03-27-2006
www.murphycabs.com
my bad, it's a Fender Dynatouch Stage 1000. No CRTs period, and it's the same whether I'm in front of the amp or down the hall. I checked over my cables, they seemed fine, I unscrewed the housings and the connections are tight, nothing touching, no frayed wire, etc. I tried damn near every cable I could get my hands on, all the same results.
My Generic Crap
  #14
Old 03-27-2006
ggunn ggunn is offline
Crystal Flavolian
ggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond repute
Some amps short their input to ground when nothing is plugged in. To see if that is the case and the problem is in the amp not the connections, get a 1/4 plug that has nothing soldered to it, insert it into the amp's input, and see if you still have the noise.
Gordon in Austin
http://www.crystalflavola.com
  #15
Old 03-27-2006
www.murphycabs.com
I did try just plugging a cable into the amp with no guitar on the other end, and it was just as apparent as before, so I think I can rule out the guitars as the problem.
My Generic Crap
  #16
Old 03-27-2006
gcapel's Avatar
gcapel gcapel is offline
boom box recordings
gcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond reputegcapel has a reputation beyond repute
Acoustics in your old place may have been better and the hum has always been there. I would borrow another guitar and another amp, to isolate the problem.
  #17
Old 03-27-2006
dirtythermos dirtythermos is offline
Dedicated Member
dirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond repute
It's most likely the power in your new house. Try a power conditioner, or take the amp to a friend's house and try it there.
Third Take a blog about home recording
  #18
Old 03-27-2006
jaykeMURD's Avatar
Chocolate Rain
Exactly the same situation I was in. It's simply the power in your house fluctuating and creating hum. A line/power conditioner will most likeley take care of it!
  #19
Old 03-27-2006
www.murphycabs.com
Thanks for the info guys, much appreciated. Oddly enough, in over a decade of playing, using misc. amps, etc. This is the first time I've encountered this problem. I'll pick up a line conditioner or something similar in the next day or so and see if that takes care of it. Thanks again!
jaykeMURD, I see you're from Ohio as well, where at?
My Generic Crap
  #20
Old 03-27-2006
Anfontan's Avatar
Anfontan Anfontan is offline
Banned by eurt
Anfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond reputeAnfontan has a reputation beyond repute
You may try one of those ground checkers from Radio Shack to check all your outlets since it started in your new home. Some utility companies dont have a well regulated 60 cycles on their AC lines, plus you can never tell what kind of wiring lurks behind the walls.
  #21
Old 03-27-2006
jaykeMURD's Avatar
Chocolate Rain
Haha. When you say "Ohio Valley" it doesn't nessicarily mean the person lives in Ohio. It's a referance to the Ohio River and the states it runs through. I live in Kentucky!
-Thought I'd save you the trouble of embarrasing yourself!
  #22
Old 03-27-2006
www.murphycabs.com
It'll take more than a Kentuckian to embarass me. Though I will admit that I overlooked the "Valley" part, but still would have assumed you were from a decent state.
P.S. Bring me some cigarettes
My Generic Crap
  #23
Old 03-28-2006
jaykeMURD's Avatar
Chocolate Rain
Don't think you wany Kentucky cigs, look what happens after a few years of our cigarettes:
  #24
Old 03-28-2006
smileypaul smileypaul is offline
Newbie
smileypaul is on a distinguished road
Ill disagree with everyone else here.. its most likely not the power in your house, and a power conditioner will probably not solve the problem.. it will however, create a small problem in your wallet.
Most likely the pre-amp tubes.. have someone look at them.. replace them.. rebias.. have htem check all solders as well...
  #25
Old 03-28-2006
www.murphycabs.com
I've got a line conditioner to check it with, I just lack the time to move some gear around. If that doesn't work I was planning on taking it to a local shop to see if they could give some advice, thanks for the post!
My Generic Crap
New webpage explaining speaker impedances, etc. gusfinley Guitars and Basses 11 12-04-2005 04:27
BR-8 DIgital noise and Amp recording katmandude Roland, Boss, VS Series Forum 8 08-05-2003 17:40
Lexicon 284 Class A Recording Tube Amp Pearldiver Free Ads for Music / Recording Equipment 2 08-02-2002 19:30
how do they kill amp noise? cordura21 Recording Techniques 4 02-12-2002 11:25
