Ducking/Sidechaining in Waves C1.... HELP!
I need help here... I have a very intrusive bassline on a track I'm mixing for a client, and simply scooping the frequencies or using a volume envelope isn't working.
I have the Waves C1, but I'm not quite sure how to use it for Ducking the bassline so the kick comes through clearly. Can anyone tell me how I can do this? I don't see a way for me to use an input source (the kick track) to duck the bassline. I'm using Adobe Audition as my DAW and I have the C1 as a VST. Any help is greatly appreciated. BTW, I searched the forums and found plenty about ducking techniques, but the only Waves C1 stuff I found had to do with Cubase and it's WAY different than Audition. Thanks. -Change
http://www.changehiphop.com/images/pics/Signature.jpg Preview of the new Album here!!! Mixing and Mastering services for your project, contact change@changehiphop.com |
You need to use the "C1 comp - sc" plugin, rather than the regular C1.
Also, when you're using it for ducking, each instance of the plugin can only work with a mono signal. So if you want to process stereo, you need to run two instances. Here's how I do it: - Create a new bus - Add the C1-sc to the FX bin on the bus - On the C1-sc, change the "Key mode" option from "Stereo" to "L->R". This means the left signal will be used to control the amount of compression, which in turn will be applied to the right signal. (You can use R->L if you prefer. There's no functional difference.) - Add a send to the kick drum and bass guitar tracks, each going to this new bus. On the kick drum track, pan the send left, and on the bass guitar track, pan it right. - Adjust the settings of the C1-sc to taste. The bus now outputs the ducked signal. It's a bit awkward, for sure. If you have access to it, the db audioware compressor handles sidechains much more intuitively. |
| BEWARE - iLok required for Waves Plugs | PhiloBeddoe | Other Equipment and Reviews | 39 | 12-05-2005 12:50 |
| Izotope Ozone 3? or Waves L3? | Cdacoron | Mixing / Mastering | 9 | 11-29-2005 13:59 |
| No More Waves | tkingen | Cakewalk / Sonar Forum | 5 | 03-01-2005 10:29 |
| adding and subtracting sine waves? | SEDstar | Mixing / Mastering | 2 | 08-21-2004 09:57 |
| Low Frequency Waves need to develop? | KingstonRock | Studio Building & Display | 3 | 09-04-2003 16:03 |
