Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 03-25-2006
MessianicDreams's Avatar
MessianicDreams MessianicDreams is offline
Throbbing Member
MessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond reputeMessianicDreams has a reputation beyond repute
approaches to Multiband Compression - your ideas please!
Heya,
Having recently aquired a multi-band compressor plug-in, i'm now starting to begin messing around with it. i'm pretty familiar with how it works and what the controls do, as i'm very familiar with using compressors.
I've read a few things on the internet about how to use mbc, and rather than a re-hash of that i was hoping for some rather more home-grown knowledge with some of those quirky tips and tricks that you wouldn't necessarily find in an article.
When do you pull out the mbc? what do you use it on - individual tracks, across an entire mix, uniquely during mastering or also when mixing? what sort of settings do you use in particular circumstances (obviously these will change depending on the program material)?
i'm hoping this will turn into an in-depth discussion on the implementation of mbc...
happy hunting!
MD
There are 10 types of people...those who understand binary and those who don't
My humble home studio!
My Choons
My DIY Broadband absorbers thread!
Mbox2, MacMini (Intel), Mackie HR624, Focusrite Liquid Mix, Frontier Design AlphaTrack
Old 03-25-2006
tarnationsauce2's Avatar
tarnationsauce2 tarnationsauce2 is offline
Welcome to the jungle.
tarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond repute
Here is a good read:
http://www.soundonsound.com/sos/aug0.../multiband.asp
Old 03-25-2006
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
For a beginner MB compression user, think about it as something you use on material -- be it individual tracks or full mixes -- that has things that "pop out" at you from time to time that are mostly frequency-specific.
Probably the simplest and most common example of a MB compressor is the de-esser. When you consider the vocal track, the "ess" problem is something that 'pops out' at varying intervals (whenever the singer makes the "ess" sound), and it's frequency-specific, as the trouble exists mostly in the higher registers above 4 khz.
In that example, you use a MB comp / de-esser as a means to tame those peaks only within the frequency range(s) where the problems existwithout effecting everything else. Another good example might be bass guitar. You might notice -- especially if you play bass -- that there might be certain notes, that when you hit them, they suddenly stick right out and sound louder than everything else you've been playing to that point. And usually it's somewhere on the low-E string. MB compression can, again, be effective in dealing with those sorts of issues, because, again, you're dealing with something -- in this case, a note or a string -- that suddenly "pops out" every time you play it. And it resides in a narrow frequency range.
If you think about compression as sort of an intelligent, automated gain-riding control ... think about MB compression as an intelligent, automated EQ-riding control. Whenever the energy within a given frequency range reaches a certain threshold, the MB comp will automatically apply subtractive EQ to deal with / tame it ... after which time, it will return to normal.
These are the simplest examples, and most common uses of MB compression, so if you're new to the concept, I think it's important that you try and wrap your brain around those first, before you delve in to anything more complicated. Because once you fully master the idea/concept of it in those contexts, then the more complex stuff will eventually present itself to you, and when it does, it will be easier to learn and will make much better sense to you.
Old 03-25-2006
Dogman's Avatar
Dogman Dogman is offline
Campeón de la Internet
Dogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond repute
Good read man...
I won the internets......
Old 03-25-2006
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
Agreed. Very nice post, chess.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
Old 03-25-2006
Throbbing Member
i had already read that article tarnation, very good stuff i think. informative, not too in-depth, well written.
very interesting response chess, i am familiar with the concept of how a mbc but it clears things up to see them written down in black and white like that. i can see many applications for mbc for fixing a particular problem, such as some of the ones that you've mentioned.
but i can also see a multitude of applications for mbc in a creative approach, you know as an "effect" to enhance a track..like pumping, or fattening up a specific spectrum etc.
good stuff guys!!
MD
My Choons
Old 03-25-2006
Synkrotron Synkrotron is offline
Midician
Synkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond reputeSynkrotron has a reputation beyond repute
aye... indeed...
in fact I find the SOS a veritable gold mine of information
I can even understand some of it lol
Old 03-25-2006
flamin-gitaur flamin-gitaur is offline
Dedicated Member
flamin-gitaur has a reputation beyond reputeflamin-gitaur has a reputation beyond reputeflamin-gitaur has a reputation beyond reputeflamin-gitaur has a reputation beyond reputeflamin-gitaur has a reputation beyond reputeflamin-gitaur has a reputation beyond reputeflamin-gitaur has a reputation beyond reputeflamin-gitaur has a reputation beyond reputeflamin-gitaur has a reputation beyond reputeflamin-gitaur has a reputation beyond reputeflamin-gitaur has a reputation beyond repute
Hey chess you feelin all right? There wasn't a smart ass comment in that post.
Earthbound Misfit
My Lil' tunes
Old 03-26-2006
chessrock's Avatar
Banned
Actually, I just noticed that, and I'm going to have to edit my last paragraph as a result. How's this? :
"These are the simplest examples, and most common uses of MB compression, so if you're new to the concept, I think it's important that you try and wrap your brain around those first, before you delve in to anything more complicated. I say this in an effort to avoid injurying your brain, as I realize most of the guys on this board have a hard enough time with the whole sm-57 versus sm-58 debate, and what color mic cable they should use for their next rap CD. Because once you fully master the idea/concept of it in those contexts, then the more complex stuff will eventually present itself to you, and when it does, it will be easier to learn and will make much better sense to you. As doubtful as that may be, although we can all dream, can't we?"
Old 03-26-2006
jonnyc jonnyc is offline
2.5K Gold Member
jonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond reputejonnyc has a reputation beyond repute
mmmmmmmmm reading that is like taking a good sh*t.
Old 03-26-2006
crosstudio's Avatar
crosstudio crosstudio is offline
Reggae + Go-Go = Regg'go
crosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond repute
multiband compression is also good for drum mixes. if your band is short on recording inputs and you are recording a live show multiband compression can help keep that kick drum from overpowering the mix.
  #12
Old 03-26-2006
Dedicated Member
Thats more like it!!!! Had me worried there.
Earthbound Misfit
My Lil' tunes
  #13
Old 03-27-2006
LeeRosario's Avatar
LeeRosario LeeRosario is offline
"The Ears"
LeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond reputeLeeRosario has a reputation beyond repute
I use this method every time and it delivers amazing results...consistently. It's amazing how transparent it sounds!
Step 1:
"Pull up a multiband plug-in and study it carefully"
Step 2:
"Throw it away and continue mixing"
"ghost" producer/Engineer
The Demure on ITunes
hip hop redrums tips ideas ofirdearie DJ & Hip Hop Production 2 01-27-2006 16:53
Control room drawing:better/worse/same? begging for ideas here tubedude Studio Building & Display 13 12-16-2003 07:41
Drawing for adding control room into live room: Better/worse/same? Begging for ideas tubedude Studio Building & Display 0 12-15-2003 14:30
All my ideas are cheesy ssseals Songwriting, Singing & Vocals 12 04-12-2002 09:27
good general ideas about demo packages? TIGERSHARK Marketing Your Music / Publicity 2 01-30-2002 07:38
