help me fix this track please
man its not coming together the way i want it
what can i do to help it. do i need to change my vocals? Psycho 2006 lo-fi URL: http://www.soundclick.com/util/getpl...d=3684006&q=lo hi-fi URL: http://www.soundclick.com/util/getpl...d=3684006&q=hi Last edited by .:Wyze Loc:.; 03-24-2006 at 07:46.. |
404 - Not Found
The road to hell is paved with good intentions. |
*links Fixed
How are you recording your vocals....I can't make them out at all. A lot of distortion and low volume is killing that.
Give us the details, software, software plugins if any, hardware used, mics, mixers? First, lets get your vocals on point and then we can figure out hwo to tweak them for the best sound possible. |
My vocals, Im using a MXL 990 condensor mic, M-audio mobile pre soundcard interface, and i use adobe audition for recording.
i record like this" t1: lay tha beat down t2: record vocals t3: record double t4: adlib double i am havin a lot of trouble figuring out the volume . |
yeah..they seam a little low..really cant hear whats goin on..
B Knot 4 bars is hip hop, no need for more if it's a hit!! "Trunks poppin'... B Knot Hits..." Boss Recordings http://www.unsigned.com/bossrecordings http://www.isound.com/boss_recordings http://www.jamwave.com/bossrecordings |
Your M-Audio mobile pre is a preamp right?
Also, when you record your vocals are you checking your volume meters in audition? I use Cubase SX myself and it's been a while since I looked at Audition (or Cool Edit Pro as it used to be). Are you connecting that mobile pre into a standard soundcard? If you are that might be 80% of the problem right there since ordinary PC soundcards can't handle vocals like that. I have a M-Audio Delta 44 soundcard that connects into a break box that my mixer, compressor, preamp, and mics all come in to. The Delta 44 runs about $150. As for how you're recording, it's hard to say because everybody has their own method of madness that works for them. I record similar to the way you do except I copy/paste the first vocal and give a very small amount of delay to it. Then I take the vocals on the second take and copy/paste it and pan one semi-hard left and the other semi-hard right. I leave my adlibs in center and then mix it all down verse by verse. I'm still working on mixing my vocals better though. Fie. |
ok, fieva holl aat me on aim right now
the mobile pre is a soundcard too
first make sure the phantom power light is on on your m-audio card.
second seems obvious but youd be surprised. check to make sure your using the front of the mic and not the back sounds a little phasey are you panning both your lead and adlibs? try listening during your breakdown the vocals get cleaner. what that tells me is your mix is to busy pan guitars here lead sound there etc carve space for your vocals i like the pitched down effect good luck dont stop tryin
www.salimtracks.com |
| Audition CD Track info problem. | Rossco | Cool Edit Pro / Adobe Audition Forum | 1 | 01-18-2006 14:13 |
| Mixing in the old tape days.... | Bob's Mods | Mixing / Mastering | 21 | 01-17-2006 05:40 |
| I Need Help With Editing. | Key Rogue | Cool Edit Pro / Adobe Audition Forum | 14 | 11-30-2005 00:37 |
| Track to Track Definition @ 44dot1kHz | Bob's Mods | Mixing / Mastering | 21 | 07-20-2005 15:27 |
| How do I get that Professional sound on my vocals? which effects settings to use? | Logik_01 | Cool Edit Pro / Adobe Audition Forum | 27 | 06-08-2003 20:47 |
