Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 03-23-2006
BrentDomann BrentDomann is offline
Nerd
BrentDomann has a reputation beyond reputeBrentDomann has a reputation beyond reputeBrentDomann has a reputation beyond reputeBrentDomann has a reputation beyond reputeBrentDomann has a reputation beyond reputeBrentDomann has a reputation beyond reputeBrentDomann has a reputation beyond reputeBrentDomann has a reputation beyond reputeBrentDomann has a reputation beyond reputeBrentDomann has a reputation beyond reputeBrentDomann has a reputation beyond repute
Odd Fret Buzz
I just noticed an odd fret buzz on my Stratocaster. It only occurs between the 12th and 15th or 16th frets on my high E string. No other spot produced an unexpected buzz while playing. And it's not the buzz that bothers me--it's the possible problem that may be the cause of the buzz.
I checked the curvature of the neck by depressing the strings on the 1st and 21st frets, and had a nice comfortable space at the 8th fret. However, when depressing the 12th and 21st frets on the high E string, my string is laying flat across the frets. This does not seem to be a problem on any other string (and, as evidence against warping, it doesn't seem to progress as I move toward the higher strings--it just 'happens' on the high E).
Here are a couple of primers that may answer questions that I expect repliers may have: This is the first time I have noticed the problem, but it's possible that it was pre-existent. I don't see any visible evidence of warping, and the frets seem particularly well-dressed (especially for a Classic Series guitar). I am the original owner of the guitar, which was purchased new in 1998. Two years ago I purchased a Fender hardshell case for it to replace the gigbag. The guitar has been kept in conditions of relatively stable temperature and humidity for the entire duration of my ownership.
First question: I know that at least for Fender basses, the curvature of the neck is not usually visibly pronounced until one gets to the 5th fret area or lower. Thus it seems the higher fret area of the neck is more level. So although the scale length is much shorter on a Stratocaster, if I'm not mistaken it is possible that the upper area of the neck is supposed to be flat. If this is the case, then my worries seem a bit unwarranted. If this is not the case, what may my remedy be?
Old 03-23-2006
crazydoc's Avatar
crazydoc crazydoc is online now
Master Baiter
Location: Please forgive me. I don't mean to be a prick, but I guess I am.
crazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond reputecrazydoc has a reputation beyond repute
I'd think all the strings would be approximately flat across the 12th to 21st frets. I'd think your bridge may be a little low on the high E side, and raising it a little should take care of the buzz.
I'm going through a difficult period - it's called life
Old 03-24-2006
ggunn ggunn is offline
Crystal Flavolian
ggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond reputeggunn has a reputation beyond repute
The nut slot may also be cut too deep for that string.
Gordon in Austin
http://www.crystalflavola.com
Old 03-24-2006
crazydoc's Avatar
Master Baiter
Except the nut has nothing to do with buzz between the 12th and 16th frets.
Old 03-24-2006
Crystal Flavolian
Oh, yeah, you're right. Duh*.
* shorthand for "I didn't read the OP's post well enough; I stand corrected".
Gordon in Austin
Old 03-24-2006
IronFlippy's Avatar
IronFlippy IronFlippy is offline
Dedicated To My Member
IronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond repute
I'd go with crazydoc on this one. Lucky for you, strats have a nice bridge adjustment system to make this easy for you. There are 2 little hex screws on each saddle. Turn them both clockwise no more than a full turn and then check to see if the buzzing is gone. Then that string will need to be intonated again. A guitar repair center should be able to easily identify the problem and fix it for pretty cheap. I'd recommend a full set up while you're there, in case there might be other problems.
I can't listen to that much Wagner. I start getting the urge to conquer Poland.
Old 03-24-2006
Nerd
I think I figured it out. After checking out my LP (which is the workhorse), it looks like the neck has the same kind of bow. What I just noticed on the Strat is that while my bridge should float about 1/8" from the guitar body, it's now only looking like it's at 1/16" or even 1/32". I might try a heavier gauge string or I might loosen the trem strings in the back of the body a bit to float the bridge a bit higher. If that doesn't work, I'll start adjusting string height (my action is pretty good, aside from the buzz).
I think that should take care of it. Thanks for all the responses, though.
Old 03-24-2006
cephus's Avatar
cephus cephus is offline
Slow Children Playing
cephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond reputecephus has a reputation beyond repute
I have heard that weird buzzes up above the 15th fret can be caused because the neck screws are overtightened and are distorting the neck.
Boo
Do not read this.
Old 03-25-2006
Light's Avatar
Light Light is offline
Born in the Light ofStars
Location: Creating saw dust at rapidly increasing levels
Light has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond reputeLight has a reputation beyond repute
It COULD be a lot of things. If the action is within spec, though, along with the rest of the strings, then I would TEND to lean towards the possibility of a high fret. I can not, of course, say for sure without seeing it, but that is my guess (or else worn frets, which amounts to the same thing). Get it to a good repair person and have it checked out. There is no reason to live with any kind of buzzing.
Light
"Cowards can never be moral."
M.K. Gandhi
"It's not about who killed my son, it's about what's killing our children."
-Aqeela Sherrills
http://www.theforgivenessproject.com/
Fret buzz - please advise stanjanssen Guitars and Basses 10 10-14-2005 14:14
Set-up Question - Tech says fret buzz is unavoidable gmiller1122 Guitars and Basses 15 05-30-2005 17:51
Bass strings buzz at every fret when lifting finger off Dennis S Guitars and Basses 6 04-08-2005 21:53
fret buzz!! help!! xfatalherox Guitars and Basses 4 09-17-2004 09:46
Help With Fret Buzz geekformayor Guitars and Basses 3 02-14-2002 13:01
