How do you record your guitars?
I have a pretty robust system that allows me to essentially go directly into to my computer to record my guitar and bass stuff. let me give you the picture:
I have an STAudio CPort breakout box that has 8 ins (2 mics with phantom power and 2 midi in/out/thrus plus an optical in that i've never used). I plug my guitar into a JStation and then I plug 2 stereo outs into 2 ins on the breakout box. I use a Roland DR5 to do midi support for things that I don't play (like drums and keys). I play the guitar and the bass thru the JStation. Does this sound like it could be too 'sterile'? I've been away from recording for a bit, but i'm getting back into it. |
Maybe not. I always record with little tube amps and 57s pointed just the right way. I think it sounds good. But I was really surprised how useable the sound was going direct through some effects using the piezo strat bridge I bought. direct used to mean yech for electric guitar. times may have changed> I am interested to see if anyone could post a short sample of some direct to console recordings of emulators that really sound convincing. Is it live or memorex?
Boo Do not read this. |
I seem to get the best results by having folks (including myself) use the amp they typically gig with, including whatever effects they use. I suggest (and do myself) record at the same volume I use at rehearsal (which BTW sounds quite loud in a room all by itself).
I use a SM57 about 3' away and slightly off axis, push the gain so a healthy strum of an open E doesn't quite clip. I've tried going direct, through pedals and pre-amps (I own both a Mesa Studio pre-amp , a V-Twin, and a POD), while I get some interesting sounds, there's nothing ike the dynamics of speakers For bass, I always go direct (unless you have the luxury of having a room 32+ feet long.... my 2 cents Stainless Sacramento |
Currently I record via my Korg AX1500G using the speaker sims as I don't have a recording amp(sold my Fender Super 60 last summer). I was sceptical about recording this way at first but the results pleasantly suprised me, so I'm pretty happy with it for now. Here's my usual signal chain:-
Les Paul Studio-->Korg AX1500G-->M-Audio DMP3-->M-Audio Audiophile 192-->Cubase SL3 Here's the first thing I have recorded since going the direct in route in terms of guitars:- http://www.lightningmp3.com/live/file.php?fid=3144 Still need to tweak a couple of things in terms of the bass and drums but as for the guitar tone, I'm really happy and like I said, I'm pleasantly suprised with the results I can get without having to mic an amp. ![]() |
I am totally different. I use a POD Pro or a VAMP2 into a Carver PM125 power amp. The power amp ia jacked into a Marshall 1X12 cab with a Celestion vintage 30. The cab is mic'd up with Shure SM7B or Sennheiser e609s or AKG C2000B, then into an Avalon AD2022, then to Digi002 to Pro Tools. So I use amp modelers, but never direct. I believe in moving air in the direction of real microphones. It sounds better to me than anything done direct.-Richie
Acoustic, mic'd with CADm177, into Presonus Firebox, into AMD, into Guitar Tracks Pro 3...
the park job in 7a |
I just use a 57 in front of the grill, no more than 4 inches away, unless it's a clean sound, in which case it might be up to a foot away. I position the mic by ear. If sarcasm doesn't bother you (and you have time to kill) then you might like Slipperman's help: http://badmuckingfastard.com/sound/slipperman.html
I can't listen to that much Wagner. I start getting the urge to conquer Poland. |
Ibanez S-470 --> Boss GT-6 --> BR1180. Direct and it sounds pretty good. Thats what people have told me. May not be "Amazing" or anything but, the people I have had listen to it say they were pleasantly surprised.
My first port of call is usually either a Pod Pro (S/PDIF out) / Pod XT (USB).
If that still doesn't work (I usually get the sound I want out of the pod) either: direct into an Avalon vt737sp or use an AKG C414 into the Avalon in front of a Marshall TSL half stack at medium lo volume or a good old fashioned SM57 (on axis pointing to the very edge of the cone, on the grill cloth) if the amp needs to be cranked !
GuitarTricks.com instructors page. www.studiotrax.net my toons Brought to you by Dr BadGAS |
amp-mic or simulator direct or clean direct or a combination.
| Tradition Guitars--Samick?? | battleminnow | Guitars and Basses | 13 | 03-04-2008 08:35 |
| Bob Taylor's approach to making guitars | dobro | Guitars and Basses | 19 | 10-15-2005 23:19 |
| Whe good companies go bad!!!!!! | Light | Guitars and Basses | 26 | 03-25-2004 13:04 |
| Best way to record guitars? | Project illicit | Guitars and Basses | 15 | 05-23-2002 17:16 |
