Creating standalone MIDI control messages
I recently purchased the Tascam US-2400 and was thinking about an idea for it and was wondering if anyone knew how I might approach this.
I wanted to try and do something similar to Digidesign's Control 24 "Vegas Mode" which rapidly moves all the faders and lights up and down....something that makes non-audio people go "Wow!" I was wondering how I might go about creating a sort of small utility for the computer where it can do something like this. Send out control information when Pro Tools isn't running to flip on lights, move panners/faders, etc. So when people come in and look at the studio I can say "yeah, I'm calibrating the unit" or something. This would be a sort of standalone program. I thought maybe a simple MIDI file set to an valid output on the USB device would work...but it doesn't do anything. Any MIDI guys think this idea might work? -B
www.redlabaudio.com |
Should be easy. Just set the control surface as midi input, move a fader, press a button etc and record while doing it. Make a couple of midi tracks this way, edit it, merge it (control surfaces usually work over 16 midi channels) save as midi file and your done.
Just like doing lighting scenes
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual |
Strange, what error?
I just tried playing a midi file with all CC's via media player and it worked fine.
But now they play fine, just no controller data gets sent to the Tascam
You want a 'midi guy' to help you fool your clients? Okay, I'll give it a try. You and Altitude 909 are on the right track, but the reason it's not workling right out of the box is probably because there's a switch you need to flip inside the Tascam that says 'midi cc receive/transmit' or words to that effect. Find the appropriate page and set that switch to both send and receive all continuous controllers. Then execute the presentation as you want it --- tempo is saved with the midi file, so slow it down to excute and speed it up before you save it.
...now in HD. |
In fact, just glancing in my manual all the commands are the same on a channel by channel basis so you should be able just to record stuff for one channel and then just copy it in consecutive clips on consecutive midi channels. They usually dont change that much for midi implementations so it should be close
| Foxtex VM200: control Sonar via the Universal Control Surface Plug-in & macro player | JJM | Fostex Forum | 2 | 05-05-2005 14:56 |
| drum machine, Cakewalk, USB MIDI interface, argh | 55337 | Newbies | 14 | 03-09-2005 16:41 |
| Foxtex VM200: control Sonar via the Universal Control Surface Plug-in & macro player | JJM | Cakewalk / Sonar Forum | 0 | 02-17-2005 10:49 |
| expansion on the midi problem | Ebicaneezer | Cakewalk / Sonar Forum | 7 | 04-11-2003 13:58 |
| Can I separately control vol/pan on drum parts on separate tracks but same midi ch. | autonickv | Cakewalk / Sonar Forum | 4 | 04-05-2001 23:07 |
