New Clips-Feedback Please
I just posted a few clips from beats i've been workin on. Trying different variety of styles. Tell me what yall think! (I haven't mixed them on the monitors yet. Headphone mixes)
Ok, clip 7 was ba-nan-nas..That joint was crazy. Was that a smple or did you play that? Clip 5, and 4 were hot too. Clip 2 had real nice melody as well.
It's easier to ask for forgivness, than it is to ask for permission http://www. myspace.com/braxx |
I played clip 7. I was messin around actin stupid wit the sound and i did that by mistake so i kept it and built the track around it. Thanks for the feedback.
Clip 7 is crazy man jus add some mo drops and stuff and u good to go. Def feelin it.
Clip 6 is ok but im def feelin dem snares and shit. Clip 5 this crack its Scott Storch and D4L mixed together. Nice man. LOL Clip 4-Neptunes sounds in there i hear em but the track is ok. Clip 3-Ok i could def see a southern rappah on dis. Clip 2-Not my style at all Clip 1-Had me goin at first but i aint feelin all da otha instrumentation.
For Incredible Prices on Music Gear-CLICK HERE! www.myspace.com/missdjcoleycole www.soundclick.com/ccproductionsmissdjcoleycole Tool Box: (Production) Akai MPC2000 Casio CTK-451(midi controller) Reason 3.0 Reaper Records/Ton of samples |
thanks for da feedback miss. By your comments i can see that you are a fan of "crunk beats". I like crunk beats too but i like to be diverse. I do all kinds of styles and i like alot of different kinds of music. I got drops and stuff in all those beats but since i'm on dial up i can't load the whole thing. I would be online forever! I just had to make short demos. I'm thinkin about puttin up a sample of my flows tommorow. That freestyle joint was wack. I was just spittin somethin. Don't base my flowability on dat. Anywayz, holla back at yo boy. Souf Cack!!
Damn i cant get enough of Clip 7. Dat shit has dat Scott Storch feel. What did u use for da track. I see u got a nice lil arsenal. Let me know.
Thanks. Believe it or not, i used fruity loops in combination with my yamaha board thru midi! I have a nice collection of soundfonts that i use. People like to rag on fruity loops but i have customized fruity loops by leaps and bounds! I do things wit that program that they don't even have in the manual. Experimentation is key.
Alot of them tracks were off the hook. I could swear I heard some "modern beats" samples in there. You got that FL going good. I use reason 3.0 and I love the sounds you are getting there. I use a similar setup, Reason, Korg Synths, Tannoy monitirs, Acid, Sound Forge. Check out my beats to and let me know your opinions. Thanks
Here are my last 3 beats (sorry for the tags, I'm selling) Sample1 Sample2 Sample3 Here is Sample 1 with a vocal track for practice Sample1 with vocals My site: Samples |
Nice beatzz mann. I'm tryin to learn reason a little bit. I've been squeezing every ounce of juice out of fl so i'm tryin to learn somethin new now. Where u get your sounds man? Nice!
#12
Reason Tricks
About half of them are from the reason 3.0 soundbank. However, they get kinda old so I layer all my sounds up to create new ones. A good trick in reason is to just start a new project, load a sampler and the redrum unit. then use 4,5 or all channels to create a bass drum sound or snare or clap etc. I export them out as a wav then reload them to use them in a sequence. I do the same for the guitar riffs, synth sounds etc. Here is a trade secret if you don't already know it. Let's say you are building a kick drum sound and you are using 5 channels. Load 5 differnet kiks or sounds and Pan each channel differently and use reverbs on 1 or 2 of them (different verbs for each) then add an eq to it to tweak it to your liking, it will be tight, trust me. I also try to add some sort of 40-50 khz freq to each note of the drum to give it punch. You could use an 808 and tweak it a little tighter to get the same effect. Hope this helps. Let me know if you want to try building a beat. I'll start it and send you the file, then you can add something to it and send it back and keep doing this til we got something.
#13
Thanks for the tip. Been doin it for a while tho. Especially before i knew i could add my own sounds to fruity loops. I started playing piano at 3. No one had taught me tho. I picked it up by ear. Picked up saxophone in 6th grade. Started makin beats on an old yamaha board in about 6th or 7th grade. I didn't even know about computer music until the summer of 2003. I started with the first fruity loops. After a while, i had to learn how to tweak the sounds to make em sound new since i didn't know how to add new ones. I use fl studio 4 now and my sound library is very extensive. I do have a few modern beats samples too, lol! I have no clue how many gigs of sounds i have. I recorded some of my own sounds also.
| microphonic feedback/musical feedback? | olfunk | Guitars and Basses | 14 | 01-09-2006 00:58 |
| Experimenting with low volume guitar amp recording- soliciting feedback (sound clips) | Deaj | Microphones | 8 | 08-17-2005 10:05 |
| Feedback | Dj17 | Digital Recording & Computers | 0 | 02-11-2005 13:45 |
| Feedback Ferret and DBX Feedback Eliminator and others | BaltJack | The Rack | 2 | 04-15-2004 19:23 |
| Behringer Feedback Destroyer - It Works | DigitalDon | The Rack | 2 | 01-12-2004 07:52 |
