cubase wont show all inputs from firebox
Hey ALL,
I have Cubase LE and Presonus Firebox. But, when I do an audio track the only input options are IN 1 and IN 2 (the mic/instrument) inputs. But, Firebox also has Line IN 3 and Line In 4 in the back of the unit. Why dont LIne In 3 and 4 show up as an input option? I'm pretty new to this stuff!!! But, Im excited to learn. |
here's some stuff to check
First ensure that your Firebox drivers are installed.
Next....in Cubase got to: Devices>Device Setup>VST Multitrack Slect The Presonus ASIO driver as the ASIO driver. Make sure all of that is done and let me know if that fixes you problem. I have a FirePod and have had no problems with this...other problems.....yeah but nothing major. |
Go to: Devices >VST Connections (or simply press F4)
At top of the VST Connections window are tabs for Input and Output, and all Ins and Outs that are currently active are listed in the Fields below. By default Cubase only creates the first 2. Click the "Add Bus" Button at the top of the window, and select a configuration from the resulting pop-up window (Alternatively "right click" in the "Bus Name" column and add one from the resulting list). Now double click the hardware in the "ASIO Device Port" column, and change it to match the hardware inputs you want for that buss. Now these new inputs are available in Cubase, and show up in the mixer and so forth. Note: You can change the name of the busses in the "Bus Name" column, when creating them, or do it later on the Mixer Channel. I find it useful to name your busses to match your external gear most of the time (I.e. Mixer Mains, Mixer Subs, To-Lexicon, From-Lexicon, etc. etc.).
Torment, Violent Aggression, Systematic State of Oppression. The Heretics, All Swing From The trees, Cast To Hell, With Their Disease. DARKENED |
I have LE and i've never seen "VST connections" as an option.
Just go to Devices>VST Inputs and click the little button next "Line ins 3 and 4" |
thanks guys. you're right. i just went into vst inputs and there it was. !!!!!
Help seems to reffer to menu pulldowns and option choices that do not exist??? |
| Need reccomendations on better inputs for my computer (aka mbox, firebox, etc) | jndietz | Digital Recording & Computers | 5 | 01-03-2006 15:02 |
| Firebox New User Questions | HungPhat | Newbies | 10 | 12-31-2005 09:34 |
| Presonus INSPIRE 1394 VS Firebox | HungPhat | Other Equipment and Reviews | 7 | 11-28-2005 22:02 |
| Hope For The Hopeless(Courses Offered From Cubase) | Sleddog72 | Newbies | 0 | 10-25-2005 17:44 |
| Digital Inputs and Cubase SE | MLS276 | Cubase User Forum | 1 | 09-11-2004 09:59 |
