Old 03-17-2006
chrishisey chrishisey is offline
Newbie
chrishisey is on a distinguished road
Visuals Flat In Sonar 5.
I have no idea what to call this problem... My computer crashed halfway through a recording session.. i had to do alot of punch in's on guitar and need to edit a few of them.. but my computer crashed right after saving.. and now were the visuals are (the wave peaks) are just a flat line... still plays right in the time line.. but Make's it hard to see were one starts and stops without paying attention to all the milliseconds... any way to rebuild the tracks?
Old 03-17-2006
Newbie
p.s. I'll make a screen shot if that would help someone?
Old 03-17-2006
jmorris's Avatar
jmorris jmorris is offline
livebandrecordings.com
jmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond reputejmorris has a reputation beyond repute
I have had this many times. I assume you see a flat line in your track view and can hear sound but can not see the wave form? I have exported the track to a program like sounde forge, added a bit of compression, I mean the least amount possible, then brought it back into sonar and the wave is there no problem. Just alter the property of the wave slightly and it reappears.Probably not the right way but it does work. Some people here say to increase your picture cashe to like 200 or 260. I have done that and it has not helped. The problem sucks.
Jim
People always seem to embrace the future then long for the past
Old 03-18-2006
crosstudio's Avatar
crosstudio crosstudio is offline
Reggae + Go-Go = Regg'go
crosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond repute
I've seen this b4 in older sonar and CPA versions. I fixed it by wiping out the picture cache.
also, is it possible that you have a second track masking the first one? Can you drag that clip to a new track?
Old 03-18-2006
acidrock's Avatar
acidrock acidrock is offline
Purge's arch nemesis
acidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond repute
You can also try bouncing to another track.
Old 03-18-2006
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
I agree with Crosstudio, this is the result of your picture cache (where the waveforms are stored). However, you don't need to wipe it out, since eventually Sonar will redraw them on its own and replace the oldest ones in there.
The way the cache works is that it stores pictures of the waves - up to the capacity of the cache. When the cache gets full, Sonar will overwrite the oldest files and replace them with the current ones. For some reason this can sometimes take quite awhile.
You can help the situation by devoting more of your hard drive space to the waveforms. To do this, go into the Sonar "aud.ini" file using a text editor. Find the line that says PicCacheMB=20 and raise the 20 to something like 100 or 200. (The more the merrier, depending on the size of your hard drive.) Then resave the file under the same name.
That should minimize the amount of times this happens.
Old 03-18-2006
Newbie
alright:
Bouncing doesn't work. There is no sound on sound making.
Porting it to sound forge (witch I have done before I posted this... but useualy only when something needs to be edited) works.. but I do worry about compromiseing the sound file.
I'm pretty sure the picture catche might being it back if i wipe it out... but I think the pictures it stores is getting errors due to the improper shut down of the program..
I was figureing there was a redraw feature that would just redo the trick.. I havent been able to find a answer that works in any f.a.q or cakewalk boards becides porting it out to a sound edit program.... maybe it's just a crappy bug and thats the only way.
Old 03-18-2006
Newbie
Yeah... wiped out the picture cache, did the trick.
Old 03-18-2006
jmorris's Avatar
So, you deleted the pic cashe and it re-drew the waves fine?
Old 03-20-2006
crosstudio's Avatar
yup. that's the ticket. i haven't had to do it in sonar5 so far, but did it plenty in older sonar and CPA releases.
Sonar 4.......some questions Magnum Cakewalk / Sonar Forum 25 07-15-2006 11:27
Sonar and UAD1 fans Middleman Cakewalk / Sonar Forum 18 01-29-2005 01:38
MTC and sync problems with Sonar and Akai DPS16 PhillipT MIDI Mania 3 01-12-2005 14:50
Just an idea for Sonar.... Still' Dreamin' Cakewalk / Sonar Forum 10 08-14-2002 16:11
How to : Sonar midi -> wav (I have a sound card) cowby Cakewalk / Sonar Forum 1 07-29-2002 08:15
