Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 03-17-2006
Motioneso Motioneso is offline
Newbie
Motioneso has a reputation beyond reputeMotioneso has a reputation beyond reputeMotioneso has a reputation beyond reputeMotioneso has a reputation beyond reputeMotioneso has a reputation beyond reputeMotioneso has a reputation beyond reputeMotioneso has a reputation beyond reputeMotioneso has a reputation beyond reputeMotioneso has a reputation beyond reputeMotioneso has a reputation beyond reputeMotioneso has a reputation beyond repute
Oxygen 8 and Reason 3.0
This really isn't what I would have chosen for my first post to be, but I am stuck and everyone here seems to be experienced in some sort of fashion, and the people in the M-audio and Propellerheads forum seemed to be unable to respond (although I asked quite some time ago... so not their fault)
I have an Oxygen 8 (the older model), but for some weird reason I can't get it to interface with Reason 3.0 on my desktop. I know this keyboard works, because I used it with Reason 2.5 and 3.0 on my Tablet PC for live shows and worship gigs, but I can't get it to interface with either version via the desktop.
The desktop itself finds the keyboard, and recognizes it as M-Audio USB Keystation...So I figured I would uninstall and install Reason again, so I do. After it's done loading up all the banks it does the auto Audio scan and even finds that I have the Oxygen 8 (older model) and says it will use that as the default control surface. So I am thinking sweet, it's working! But then I load up various instruments and I can't seem to have control over anything.
Any help here would be greatly appreciated!
Thanks,
Ben
www.clairmontonline.com
www.myspace.com/clairmont
Old 03-18-2006
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
In Reason 3.04 the 'remote' features are spotty at best.
Even with a controller with enough knobs for everything (I have a BCR2000 tied to Reason) it still doesn't give you access to every single parameter. One example would be the Redrum - it only gives you control over the first eight channels leaving the last two begging.
Until Propellerheads design and market their own controller --- which may never happen --- you'll just have to use a combination of the controller and the mouse, like all the rest of us.
I have an old model Oxygen 8 too, and I got so frustrated trying to use is with Reason 3.04 that I gave up and tied it in elsewhere in my system.
...now in HD.
Old 03-18-2006
Newbie
It's not so much that things aren't working properly, it's just that things aren't working at all. For instance, if I load up the Subtractor I can't get any input single from the controller (the note on button never lights up), so I think something is just plain messed up somewhere
Old 03-20-2006
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
Are you routing the master to the instrument track? Its the little keyboard next to the corresponding instrument in the sequencer pane
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 03-20-2006
Info you can use...
There's a drop-down menu that shows itself when you do a right-click on, for instance, the Subtractor which allows you to "lock to Oxygen 8" --- have you tried this yet?
...now in HD.
Old 03-20-2006
Newbie
Cool
Still no luck, so I am taking an alternate route. I just got a new 60gb harddrive for my Motion M1400 so I will be dedicating that drive simply to reason and nothing else. I figure that with 1gb of ram should do some pretty good stuff for live shows and recording. Thanks for the responses anyway!
Ben
Reason 3.0 Trumpspade DJ & Hip Hop Production 8 01-26-2006 15:07
trouble w/ fl 6 w/ reason midwest Digital Recording & Computers 0 01-11-2006 04:31
MIDI to Reason interface question Repeater MIDI Mania 3 09-28-2004 07:46
ReWire2 Problems: Cubase and Reason Trouble ScienceOne Cubase User Forum 4 08-07-2002 21:02
Cubase and Reason: Rewire2 troubles ScienceOne Digital Recording & Computers 0 07-31-2002 21:44
