Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 03-17-2006
mr. torture mr. torture is offline
Senior Member
mr. torture has a reputation beyond reputemr. torture has a reputation beyond reputemr. torture has a reputation beyond reputemr. torture has a reputation beyond reputemr. torture has a reputation beyond reputemr. torture has a reputation beyond reputemr. torture has a reputation beyond reputemr. torture has a reputation beyond reputemr. torture has a reputation beyond reputemr. torture has a reputation beyond reputemr. torture has a reputation beyond repute
Midi hookup question
Hello all,
I need to know if this can be done. And if it can be done, how do i do it?
I have a Yamaha AW4416 hooked up through midi to an Akai MPC2000XL.
Basically i use the Yamaha to send MTC control to the Akai to run them in sync. What i would like to do is add a keyboard into the chain. This keyboard has a built in sequencer and midi capability. I would like to have all 3 work together in sync. When i press "Play" on the Yamaha, the Akai starts up and follows along. I would like for all 3 to follow along. I hope i have explained this well enough. Thanks for any help you may be able to provide.
Old 03-17-2006
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
I would just use the MPC sequencer for everything and use the keyboard as an input on the MPC. Otherwise, just use the midi thru on the MPC and connect it to the keyboard
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 03-17-2006
Senior Member
Thanks for your help!
Old 03-18-2006
crosstudio's Avatar
crosstudio crosstudio is offline
Reggae + Go-Go = Regg'go
crosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond repute
Or you can buy a midi splitter so that you can send the midi output (including MTC) from the keyboard to the AW4416 and MPC without having to worry about whether your timing will start to drag.
REALLY simple MIDI question! Help! appleking MIDI Mania 3 07-16-2005 19:23
Midi and Creamware dangerman MIDI Mania 3 05-18-2005 00:53
Drum Machine Midi Question - Alesis DM-Pro ebitda Cubase User Forum 2 05-23-2004 17:43
MIDI hookup question. NLAlston MIDI Mania 6 03-21-2004 17:28
Need serious midi help whats the best way to do this? puppethead MIDI Mania 3 10-09-2003 15:59
