Midi Volume
Hi. I'm using Cubase SX3. My midi track is set to 127 and I cannot raise the level of each key (synth uses dynamics - must stay the same). Is there a gain plugin or other way to do that?
Thanks |
a) turn everything else DOWN or
b) render the track to audio and then slap a compressor on it (of course that will kill the dynamics of the track if you hit it too hard....) |
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual |
Increase the VST and MIDI volume. As altitude said... these two are different thing.
I'm still thinking of one!! |
On the mixer, you should change the channel of the MIDI CHANNEL to be the same you're using.
If you use a Drum map and try to set the volume on the mixer, it won't work, because by default the mixer channel will control the MIDI channel 1 volume. For the drum map you should use channel 10, which is by default the channel for the drums sounds on the MIDI sound bank of a soundcard. |
| How do I hook everything together? | mikara | Newbies | 20 | 09-02-2005 05:27 |
| The wrist bone is connected to the hand bone; help with MIDI and USB concepts/setup | f. lai | MIDI Mania | 4 | 07-13-2002 13:55 |
| Adjusting midi volume after a note has started | aljordan | Cakewalk / Sonar Forum | 7 | 04-22-2001 14:59 |
| Here is a solution for Midi Sync with a VR800 as the Master using Cakewalk! | Rish | Fostex Forum | 0 | 12-12-2000 13:32 |
