hi everyone ...
i'm pretty much a cubase newbie ... anyway is there a way to compose drum lines using drum wavs in cubase ? or do i have to use drums that come in devices ( like hypersonic or lm-4 etc... ) if it is possible to make a device of my own using wav files or somehow compose drum lines using wav files pleaaaaaase help ............. thanks ![]() |
Well, you could place your wavs into position using snap-to-grid manually, but that'd take forever...
Otherwise use some MIDI drums or sample loops. Or a combination of both. Which version of Cubase are you on?
Cubase SX3, Pro Tools M-powered 7, Sound Forge 8, Mackie 1402 + 802 VLZ3, Rode NT1a + NT5 matched pair, ATH-M30 h/phones x 3, Roland XV5050, Yamaha Motif Rack ES, Korg 05R/W, Samson C-control, Event TR8s, lots of VSTis and samples... |
"Introduce a little anarchy. Upset the established order, and everything becomes chaos. I'm an agent of chaos. Oh, and you know the thing about chaos? It's fair..." |
Hi will, it kinda hard to do that. Run FruityLoop (do you have one?) VST in Cubase, do the sequencing there. Just my 2 cents.
I'm still thinking of one!! |
i'm using cubase sx2
i actually found a nice way
hey people ... i actually found a nice way of using wavs of my own
i just took a device that has samples of it's own and i replaced the wavs of that device with wavs i wanted to use ( i changed the file names of the wavs i wanted to use to the names of the device's wavs ) pretty cool ... although now i'm trying to figure out how to add reverb to my drums ... is that possible even ? will it be better to just export the drum lines to a wav file and maybe edit it as wav ? + does anyone have a suggestion on how to mix drums in order to get a professional feel to it ? .. you know make it sound how drums sound on songs you listen to on cds etc... |
Yeah I would say mix it as a wav file. But possibly make each piece its own wav file by mixing it down, with only one of the drum pieces solod. Go through every piece and do that, then stick your new wavs into individual tracks, so you can mix the drum kit better in the mixer. Then run all the new drum tracks into a group track. Stick some reverb on the group track and all your drums with have reverb and you will have lots of control over the levels of each piece.
what's a Spectrum Analyser ?
what's that Spectrum Analyser iv'e seen it on the menu but i never touched it ...
what is it ? what does it do ? |
I use a combination of different methods. Each has its stregths and weaknesses. This also depends on the musical genre.
When working on Drum and Bass for example (the genre, not the instruments), I'll start off with a sampled breakbeat, make sure it loops correctly, then chop it up with either ReCycle or using the HitPoints. At this point obviously I'll be at the audio track level. Next step will be either bringing in another breakbeat and layering that with the first one, or layering individual drum hits to support the main kick and snare hits for example. At this point it is important for me to work on audio tracks so I can zoom in and make sure I line up the layered hits so that they're in phase with each other. Once the basic loop is done, then I bounce the whole mess, open it up in ReCycle, chop it up, and export MIDI. Then I'll load the chopped loop in either something like NI Intakt/Kontakt or shoot them over to the Kurzweil K2600. Back in Cubase, I create a MIDI track, set its output to whatever it is that's going to play the loop, and import the MIDI file created in ReCycle and sequence from there. Other times, if I'm working with individual hits, I'll just load them up in Battery and sequence the drums that way. For the odd hits that occur once or twice in a track, I won't bother with loading them in a sampler, I'll just put them on an audio track at the appropriate moment.
Spectrum Analyser is a small plugin that you can use to analyse the frequency spectrum. I am using Inspector.
| bad drum sounds | noground | Recording Techniques | 20 | 08-26-2006 08:56 |
| Drum samples w/ Cubase and Boss DR-660 | DC-XPL | MIDI Mania | 4 | 11-30-2004 14:12 |
| drum samples into cubase vst 24 | the blues daddy | Cubase User Forum | 8 | 11-10-2004 16:50 |
| new to cubase please help with drum editor | stealingsilver | Cubase User Forum | 3 | 10-25-2003 18:00 |
| Drum maps in Cubase SX | kevellus | Cubase User Forum | 1 | 06-13-2003 02:43 |
