Cubase with Fantom X-6 Korg 1600mkII & EMU 0404 MIDI Config
I need serious help with configuring the following equipment to record properly.
Phantom X-6 (Sometimes the sounds in the keyboard itself & other times as a softsynth controller) Has 1 Audio In 4 Audio Out Put 2 R /2 L Digital I/O Coax MIDI In/Out/Thru MIDI/ Storage USB Connection Korg 1600mkII(Used mostly as a mixer and for tracking prior to rec in cubase when recording audio need for this to sync) Has Optical SPDIF In/Out & MIDI In/Out & 8 Audio In 2 Audio Master Out 2 Audio Monitor Out 1 Audio Aux Out Cubase SX (Used for Mixing, Mastering, Signal Processing, Editing) Need to be able to record MIDI Data From X-6 to it and use X-6) to controll sof synths in it.) All Run Thru my EMU 0404 Soundcard using Patch Mix DSP My Emu has Optical SPDIF I/O COAX SPDIF I/O (both can run simutaneously as long as they are both transfering same exact signal) MIDI I/O 2 1/4 Audio Ins 2 1/4" Audio Outs Who Is Master/ Slave/ MIDI Slave/ MTC Slave/ Remote????? & When? What is the Dif Between MTC Slave MIDI Slave & Remote. Someone Please Help. I'm ready to give up.....on MIDI. |
| Using my Fantom X6 as midi controller in Cubase VST? | junkmanistan | MIDI Mania | 3 | 11-18-2005 23:38 |
| Midi control in Cubase VST 5.1 | junkmanistan | Cubase User Forum | 0 | 11-16-2005 12:41 |
| MIDI config | Tonio | MIDI Mania | 24 | 05-19-2003 19:11 |
| Midi Connections in cubase | Bobcat102122 | Cubase User Forum | 1 | 06-11-2001 12:02 |
| Cubase 5/G4/Fastlane Midi problem | wormhole70 | Cubase User Forum | 1 | 04-23-2001 03:14 |
