Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 03-07-2006
ericlingus ericlingus is offline
Force of Nature
ericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond reputeericlingus has a reputation beyond repute
Applying reverb in Cubase LE
I want to create a cavernous sound. So I would like to be able to have the same type of reverb on all my channels but be able to control how much on each. How can I do this?
Old 03-07-2006
guttapercha's Avatar
guttapercha guttapercha is offline
Lovely Lad
guttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond reputeguttapercha has a reputation beyond repute
First you need a reverb plug-in. I recommend the free Kjerhaus audio; I use it on everything. Next select it as a 'send' in one of the channels. It will automatically be selected in all of your other channels because of the way that LE handles sends. Then all you have to do is pick a reverb program in the plug-in and vary the intensity within each channel.
Old 03-07-2006
pikingrin's Avatar
pikingrin pikingrin is offline
My mom says I'm cool.
pikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond reputepikingrin has a reputation beyond repute
Does CubaseLE have the capability of creating an FX channel? (sorry, I use Cubase SL3, but I'll try to help.) If it has that feature, set up a FX channel, and assign a reverb (the Kjerhaus is a nice on BTW). Then go to the other channels that you want affected, and set the sends to the FX channel. That way you can adjust the amount of signal sent to the reverb, and you also have control of the volume/pan/etc. level of the reverb as a whole so it stays uniform. Just make sure that if you do this, set the wet/dry mix of the verb to 100% wet.
Hope this helps!
-J
GFCG Member No. 000 016
SD:5058
My music...
Old 03-07-2006
Force of Nature
oh I found out how. Thanks anyways guys. What I did is created a stereo track, then routed a send effect(only the send effect not the whole channel) to a bus or it could be a group channel. Next I pick out a reverb I want and apply it via insert not send. Then I mix the reverb so its 100% wet. The fader on the group/bus track now acts as a level control for the reverb and for the rest of the channels that I want to put th ereverb on, I control the amount with the send level slider on each track.
Old 03-07-2006
Force of Nature
guttapercha, hmm maybe I could just do it that way. I'll try it out haha. MUCH more simple than my method..
Old 03-09-2006
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
Devices-->VST Send Effects-->Select your reverb
On each channel display, on the far right, you can determine how much signal to send through the effect.
"That was so terrible, I think you gave me cancer!"
My tunage
reverb compressions in cubase sx Adrenaline Cubase User Forum 3 01-17-2005 20:41
BR 1180 reverb goes to all tracks universally? Why? undrgrnd studio Roland, Boss, VS Series Forum 0 12-21-2004 10:52
ANWIDA Soft DX Reverb - Group Buy Massimiliano To Cakewalk / Sonar Forum 2 09-23-2004 11:06
OT: ANWIDA Soft DX Reverb - Group Buy Massimiliano To Digital Recording & Computers 0 09-23-2004 10:22
ANWIDA Soft DX Reverb - Group Buy Massimiliano To Other Equipment and Reviews 0 09-23-2004 09:43
