Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 03-05-2006
NL5's Avatar
NL5 NL5 is offline
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
Freezing effects on wav track?
Hey -
If I set up a drum track with Drumagog, and get it just right, can I apply it permenantly so I can remove drumagog from the insert?
Thanks!
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
Old 03-05-2006
tourettes5139's Avatar
tourettes5139 tourettes5139 is offline
ugh..........
tourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond reputetourettes5139 has a reputation beyond repute
Originally Posted by NL5
Hey -
Thanks!
Why not? If that fails, you could always just do an audio export of just that channel, although that is more time consuming.
Check out my band!!
www.myspace.com/darkvelvetlaughter
GFCG Membership No:000 019
Old 03-05-2006
NL5's Avatar
NL5 NL5 is offline
Unpossible!
I wanna know HOW to do it - w/o exporting it.......
Old 03-06-2006
ugh..........
Oh, my bad. I was thinking that the freeze function might work. Since it passes audio through a reverb, and then applies the output of the reverb to a track, I don't see why it wouldn't do the same thing using Drumagog.
EDIT: Damn, I'm stupid. You already had freeze in your title. I would imagine that you would do it the same way that you would with any other effect. Just load up the effect into the slot, get it set up how you want it, and then hit the freeze button. Or does that not work?
Check out my band!!
Confused, in need of help? Benreturns Newbies 56 11-06-2003 04:02
can i put effects in after recording a track with my 424? Rocket Boy TASCAM User Forum 19 08-27-2003 19:34
Print just the effects to a track? adam Cakewalk / Sonar Forum 3 01-18-2003 10:23
Adding Effects...PLEASE HELP! emojoe Newbies 2 07-25-2000 17:52
Adding Effects (TC Electronic M-ONE)...PLEASE HELP! emojoe Other Equipment and Reviews 0 07-24-2000 18:48
