Old 03-05-2006
sidestream sidestream is offline
Newbie
sidestream is on a distinguished road
Mini mix 16:2 making a humming noise when i try to record....
Hello first of all thanks for checking out this thread. My 16:2 mixer is going to an amp then to my speakers. When i do this i do not hear any electronic noise or interference with the mixer. Now when i plug it directly from the left and right out on the mixer to my computer i get a very annoying loud humming noise. Now i know the wires that are going to my pc are working because it works fine with the tape out on my p.a. There is also an unbalanced line out for r.c.a. adapters. I use these and i still get the sound. I need to figure out what the problem is. I want to use the mixer instead of the p.a. because it has more channels. I dont know if the mixer is just screwed or if there is something i can do to fix it.
Old 03-05-2006
travelin travis travelin travis is offline
Banned
travelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond reputetravelin travis has a reputation beyond repute
are you actually getting sound from the boards outputs or just hum alone?
Old 03-05-2006
Newbie
well the sound comes when i actually plug in the mixer. It stays constant when i turn it on as well i have played with all settings and tried to get the rca as far away from the power as possible.
Old 03-05-2006
Banned
i'm still unclear on wether you are getting hum along with your signal or just hum alone.
i'll assume hum along with your signal. if your mixer and pc are plugged into different outlets, you could have a ground loop. if you can, connect your mixer and pc to the same outlet/powerstrip and see if that helps.
Old 03-05-2006
drumsbreathe drumsbreathe is offline
Newbie
drumsbreathe is on a distinguished road
Are you using a desktop or a laptop?
More Volume on CD Master? MONTE Mixing / Mastering 12 02-13-2005 21:04
What is the noise floor on your Delta? canada-paul Digital Recording & Computers 30 05-27-2003 06:59
Humming noise with my recording. Why? muhairwejas Mixing / Mastering 8 07-27-2002 17:01
Record your headphone mix when improvising Jan Digital Recording & Computers 0 01-10-2002 00:15
Dithering darnold Mixing / Mastering 27 12-13-2001 21:29
