Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 03-02-2006
amra's Avatar
amra amra is offline
1K Silver Member
amra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond repute
Metronome: triggering LM-4?
In the metronome settings that there is a way to make it trigger a Midi device. I have gone through all the usual steps - set up a VST instrument (LM-4), loaded a bank of sounds. On the metronome set up, I point it to the LM-4 as the midi device. If I uncheck "audio" click, but I get nothing.
What am I doing wrong here?
Old 03-03-2006
Halion's Avatar
Halion Halion is offline
1K Silver Member
Halion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond reputeHalion has a reputation beyond repute
You have to set the notes for the 1 and every other beat in the note boxes. Press some keys on your keyboard to find out where the sounds are that you want (I usually use rimshot for the accent and closed hat for the others), then select the note name in the box in the metronome setup.
metronome in sonar 4 PE is getting recorded as well thecugga Cakewalk / Sonar Forum 3 06-22-2005 08:43
recording with a metronome carbonscoring Recording Techniques 15 02-21-2004 23:31
metronome - echo but don't record? guttadaj Cakewalk / Sonar Forum 5 06-18-2003 12:35
My Metronome Problem JPlush76 Cakewalk / Sonar Forum 18 08-26-2002 23:19
Metronome... am I retarted? Brian Grey Cakewalk / Sonar Forum 27 04-03-2002 03:00
