MIDI I/O not working - Which cheap, no-frills MIDI interface?
Apparently the MIDI in/out integrated on my motherboard isn't working properly. I have an Echo Gina audio interface installed, but it has no MIDI interface. I figured I could use the onboard MIDI, but I can't seem to get it to work properly. I have the proper adaptor cable attached and the IRQ and address are set up properly in the BIOS. Under control panel-system in Windows 2000 professional everything seems to be cool and says the interface is working. When I try to record MIDI data, it doesn't happen. I'm using Cakewalk Home Studio 4XL and it appears to be properly configured using MPU-401 as the input device (I have no other devices installed). I suppose I could have a bad adaptor cable...I bought it on eBay but it was in a package and supposed to be new.
I either need a no-frills 1 in/1 out midi interface recommendation or some suggestions on how to make what I have work properly. It would be greatly appreciated! Thanks |
Doesn't the gina have midi in/out? Or is that what you are referring to when you talk about integrated on your motherboard (which I have never seen, btw)?
Is it the gina midi in/out that apparently does not work?
The fact that no one understands you doesn't mean you're an artist... |
I have an older Gina 20, it has no MIDI function. I'm using the game port of my motherboard which is supposed to provide MPU-401 compatability with the use of the proper adaptor, which I have. I'm going to check the wires with a multimeter to make sure I have a good cable to eliminate the adaptor as a possible cause. Thanks for your reply.
I have one of these. Great units.
http://cgi.ebay.com/ws/eBayISAPI.dll...ry=1287&fkxs=1 If you need more ports, I also use this http://www.soundonsound.com/sos/1997...motumtpav.html and this http://www.musiciansfriend.com/produ...are?sku=705935 you can still find these in some GCs, etc.
| Another Midi Routing Question | beatknock | MIDI Mania | 15 | 11-14-2007 04:15 |
| midi interface | Modern_Talking | MIDI Mania | 6 | 01-14-2006 21:00 |
| what midi interface is best for my budget? | bball_1523 | MIDI Mania | 4 | 07-05-2005 00:49 |
| Need serious midi help whats the best way to do this? | puppethead | MIDI Mania | 0 | 10-08-2003 22:00 |
| new studio need help.. fast!! | Readytodothis | Newbies | 8 | 04-06-2000 01:55 |
