Old 02-24-2006
Kasey Kasey is offline
Force of Nature
Kasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond reputeKasey has a reputation beyond repute
Most Important Acoustic Element
I'm a student with a limited budget, and a 19' by 12' project studio. I'm just now starting to get into how i should equip the room acoustically. Ideally, I think i'd want:
2" pyramid foam covering the entire wall behind my monitors, and the door(on the same wall).
two 2' long bass traps in each corner of the room.
twenty four 1 sqft acoustic wedges in spaced patterns on each side of the wall until about 5' behind my listening position.
some of those wedges on the ceiling
four metrofussors on the back wall, two on each side of the back side walls, and four on the ceiling.
now.... unfortunately i don't have the cash for all of these. the room is unfinished and thus has all sorts of weird oddities in the shapes on the walls - one side wall has the upper part just insulation, and the bottom half concrete. the other side wall and most of the back wall have that thin ply wood with all the little holes in it to put tool racks in. the wall behind my monitors is the inside of the wall without drywall. just two by fours and the dry wall from the other side. oh, and the ceiling is a super irregular array of vents and pipes, and the floor is concrete, except for two big rugs that i set the drumset and amps on.
which of these acoustic elements is most important?? my guess is either the absorption or bass traps, but i really want diffusors too because i want a really live sound. can anyone help me out? eventually i plan to get all of it - but most important things first.
Old 02-24-2006
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
I would pass on the diffusors for now. Getting a good mix is more important than a good live sound, which is gonna require lots of absorption in your space anyway.
Old 02-24-2006
Diffusion Diffusion is offline
Future Astrophysicist
Diffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond reputeDiffusion has a reputation beyond repute
Go with the bass traps, because bass traps absorb well at all freq's -low, mid, and high-, but 2" foam will do close to nothing for bass freq's...
Old 02-24-2006
apl's Avatar
apl apl is offline
Stand Up Comity
apl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond repute
Read www.ethanwiner.com/acoustics.html
There are cheap ways to make panels for the walls that work better than foam. Stacking fiberglass in the corners is very cost effective for bass absorption.
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser.
My tunes. Thanks!
NB
DA BEARS!
Old 02-24-2006
Force of Nature
thanks guys, i was thinking that would probably be the answer. Oh by the way, does anyone know if theres really so much different between the metrofusors and the t'fusors that you have to pay $200 for 4 t'fusors and $170 for 12 metrofusors???
Old 02-24-2006
man, if I were you, I would build my own diffusers... those auralex diffusers are extremely overpriced, and you can build a diffuser with just about anything...
Old 02-25-2006
drummerdude666's Avatar
drummerdude666 drummerdude666 is offline
immature
drummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond reputedrummerdude666 has a reputation beyond repute
apl gave a bad link.
Here's the one that works http://www.ethanwiner.com/acoustics.html
Ever notice that people labelled eccentric are usually geniuses?
Old 02-25-2006
apl's Avatar
apl apl is offline
Stand Up Comity
Oops, thanks.
My tunes. Thanks!
NB
DA BEARS!
Old 02-27-2006
lomky lomky is offline
So much to learn
lomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond reputelomky has a reputation beyond repute
hmmm, it seems Ethan's site is down.
Old 02-27-2006
Ethan Winer's Avatar
Ethan Winer Ethan Winer is offline
Why 2K?
Ethan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond repute
Lightbulb
> it seems Ethan's site is down. <
It should be back up Real Soon Now...
The acoustic treatment experts
acoustic elec vs acoustic/mic jetfixer03 Guitars and Basses 10 02-29-2004 19:46
I'm in the market for an Acoustic, maybe Acoustic/Electric, and need some guidance. Macpb Guitars and Basses 10 02-12-2004 14:52
acoustic / electric amp for sale gusfinley Free Ads for Music / Recording Equipment 0 01-31-2004 21:30
2 SM57s and a SP B1 on acoustic... dannydigital Recording Techniques 7 01-13-2004 11:05
VERY IMPORTANT... about Drum Trigguers. experiment - phase 1 Proveras Drums and Percussion 3 06-21-2002 07:12
