Old 02-23-2006
uhave2buncommon uhave2buncommon is offline
Newbie
uhave2buncommon is on a distinguished road
P A problem
i use 2 peavey TLS 6x's and a yamaha EMX 68s 6ch. pa that puts out 300 watt to each side. i cant seem to get the volume loud enough to go over the instruments in my band while practicing. should i get another powered amp to add on? or am i being stupid and missing something. If i should get another powered amp is there any recommendations?
thank you
Old 02-24-2006
GmanJeff's Avatar
GmanJeff GmanJeff is offline
Junior Member
GmanJeff is just really niceGmanJeff is just really niceGmanJeff is just really niceGmanJeff is just really niceGmanJeff is just really nice
There's no such thing as a 6X. It you're using the TLS 5X, it's a 8 ohm box, and your powered mixer puts out 270 watts into each channel at that impedence. My band uses a pair of 5X speakers, driven by 200 watts/channel. It's enough for small/medium indoor gigs and for rehearsal, but outdoors the overload protection circuits in the powered mixer kick in and shut down one or both amp channels. Your band's backline is probably just too loud for the volume you're going to be able to get from those speakers, driving them with that particular powered mixer. If the mixer allows you to connect a separate, more powerful, power amp, that's one option. Another would be to just turn down the backline to a level where the PA can keep up. You'll probably still have more than adequate volume unless you're in a larger or very crowded venue. We've found, a bit to our surprise, that most audiences and venues appreciate that we play at a more moderate volume than many other bands; louder sometimes drives away more people than it attracts.
Problem with Avalon AD2022 Richard Monroe The Rack 3 08-22-2008 16:06
Yamaha FS1-R Problem rjt Keyboards and Sound Modules 2 01-26-2004 17:46
LD Condenser Mic Problem micr0s Microphones 5 01-09-2004 00:24
Unwanted distortion in amp; possible preamp tube problem? Whoopysnorp Guitars and Basses 11 09-16-2003 13:06
Strange snap crackle pop problem tlee2951 Cakewalk / Sonar Forum 12 08-08-2003 10:44
