Go Back   Home Recording > User Forums by Brand > MiniDisk Forum
     Audiofanzine Homestudio Homestudio News Homestudio Medias Homestudio Tests Homestudio Articles Homestudio User Reviews Homestudio Classifieds Ads
Old 11-16-2000
Nilbog's Avatar
Nilbog Nilbog is offline
hello
Nilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond reputeNilbog has a reputation beyond repute
Exclamation
okay, this is weird. Usually, I use a patch bay with my md8. It has worked fine so far.
But today, I couldnt get hardly any sound out of channels one and two (using the XLR inputs). I thought maybe I had blown the pre-amps. So I messed with it a while, and eventually got it to work again by unplugging the channel 1 and 2 1/8th" plugs that were going to the patchbay.
I couldnt believe it! How are these things even related? Why should it matter so long as nothing is plugged into channel 1 and 2 on the patchbay?
I cant figure it out. But I guess from now on I'll just leave the 1/8th" plugs unplugged.
Old 11-16-2000
bvaleria's Avatar
bvaleria bvaleria is offline
Recording Genius
bvaleria will become famous soon enough
Possibly normalled connections??
Bruce
Old 11-16-2000
Nilbog's Avatar
hello
What does that mean?
Old 11-16-2000
bvaleria's Avatar
Recording Genius
Normalling connections in a PB means that there is signal flow between the top connector and the bottom connector of a patch without requiring a jumper - the "normal" state - plugging something into the patch at that point breaks the normalled connection and stops the signal flow. If your PB is normalled, then you could have inadvertently made a connection that interrupts the "normal" flow.
BUT............ I just re-read your post and it don't think it's the PB at all - on lots of semi-pro gear you can't connect both XLR and line-inputs at the same time - must have something to do with the load and the way the connectors are wired.
Bruce
