PCI vs USB/Firewire
I am curious of the pros/cons between using an onboard PCI card,
such as the Audiophile 2496 or Delta 44, versus using a USB/Firewire box such as the Lexicon Omega or the Firepod. I'm at a bind at where to go next for my setup, to get optimal performance, and want to get as much information as I can. I currently am using a Lexicon Omega, but also have a 2496. Since determining I need a pre-amp for my Shure SM's, I'm curious which to use. Thanks for any input. |
Please, anyone.
I personaly like USB/firewire more, more specifically firewire. They're just more convenient I think because you can do location recordings with a laptop. But that's my only argument. I use to use the Omega as well. You don't have to have preamps to use it.
The Omega does have preamps, and nice ones, but for some reason, as with some Firepod/boxes, the SM-57 sometime needs a pre-amp for low volume recording.
I just feel like I'm missing something, using a desktop to record, as if its more logical to use a PCI card. |
USB has really bad performance problems for audio above about two tracks.
USB is fine for cheap hard drive cases or thumb drives, but for audio, stay away. PCI has decent performance, but poor longevity. The parallel PCI standard is basically deprecated for new designs, replaced by PCI Express (PCIe) which is not compatible with PCI cards. The phase-out of legacy parallel PCI has already begun. Here are the expected phases, along with my best guess about time frame:
The PC industry is currently in phase 1. The Mac platform (hardware-wise) has already dropped parallel PCI in new designs. A lot of the motherboard manufacturers will probably follow suit in many of their designs in the near future, as PCIe is significantly easier to use from a board design perspective, which will put us in phase 2. There is already some talk of phase 3 being imminent in hardware circles. For cheap devices (<$100), PCI is fine. You'll probably outgrow them before you end up with a machine that doesn't support parallel PCI. Even if you don't, you haven't lost that much more than buying a decent FireWire card to support a FireWire interface. For more expensive devices, I'd be wary of anything but FireWire. USB just isn't reliable enough, and your computer will probably outgrow a high-end PCI interface before you do.
Thank you for that great post. It was enlightening, and I actually cancelled my 1010LT order for a Firebox. Thanks again.
Go for Firewire or PCI.
PCI is more stable. However you may not be able to record it with laptop. In our experience, some presonus and yamaha Firewire is less stable. Sometimes we got sync drop, or perhaps having sound drop/click. Maybe it's a hardware conflict. Computer/PC/Windows stuff is more complicated than metaphysics. Try Motu/RME/Echo Audio firewire audio interface, if you are insterested to. The big pros in firewire: You can do very clean and quiet recording session with laptop. Then send the audio file back to your main station for mixing. ![]() |
| PCI Express question..... | kranky | Digital Recording & Computers | 22 | 10-24-2005 16:49 |
| Random Crackles on Recording | Leachim | Cool Edit Pro / Adobe Audition Forum | 49 | 10-27-2004 14:02 |
| FS: RME Digiface with PCI Card | lunatic | Free Ads for Music / Recording Equipment | 3 | 04-12-2004 19:13 |
| IEEE 1394 Firewire, USB, PCI, and the future of PC/Mac Recording | pisces7378 | Digital Recording & Computers | 13 | 04-28-2002 04:24 |
| Overclocking. | tonester | Digital Recording & Computers | 7 | 10-16-2001 14:49 |
