Old 02-22-2006
peritus's Avatar
peritus peritus is offline
"The Fountainhead"
peritus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond reputeperitus has a reputation beyond repute
Reason Rewire Levels
Okay... I posted this elsewhere. However, I decided that it would be better to delete it and start a new thread on this subject.
I want to make sure that I'm getting the best possible sound out of Reason and into Pro Tools (I have M-Powered 7).
Based on the information provided to me in this thread and elsewhere, I am shooting for the following (in general).
In PT:
Aux/Instrument gain fader should be set to 0 dbfs.
BF Meter Bridge plug-in, placed directly after the ReWire insert (in the signal chain), should be set to -15 dbFS Meter Calibration and RMS.
While playing the song, the VU meter on the Meter Bridge should show a reading that is as close to 0 dbVU as possible, without going over (during the loudest passages).
After flipping the RMS vs. Peak switch to Peak and the Meter Calibration to 0 dbFS, the meter should not read a value over -6 dbVU (during the loudest passages).
Also, the clip light for the track should NEVER light up.
If these requirements are not met, the instrument's settings, in Reason, should be modified to get the signal within spec. Also, effects processing could (but I'm not sure about should with this one) be used on the PT end to further enforce the specs (Keep in mind this is the mixing stage).
If you are willing to, please critique this procedure and help me perfect it.
The problem I see in this has to do with the RMS metering. If the instrument produces intermittent content, its RMS will be naturally low.
Thanks,
Peritus
Joshua Dotson, Peritus Sound
SoundClick
Old 02-24-2006
peritus's Avatar
"The Fountainhead"
Can anyone shed some light on the topic?
SoundClick
Studio Projects Customer Service Richard Monroe Microphones 107 12-22-2005 16:54
Cubase, Rewire and Reason Electric Sugar Cubase User Forum 0 07-30-2005 13:37
Latency adjustment in REWIRE mode with REASON joergb Cool Edit Pro / Adobe Audition Forum 1 11-08-2004 01:24
Generic Rewire question rjt Digital Recording & Computers 0 04-10-2004 09:46
ReWire2 Problems: Cubase and Reason Trouble ScienceOne Cubase User Forum 4 08-07-2002 21:02
